Bug(s) when D&D a sample from FL Studio to Audacity.
Hussam Eddin
Post by Hussam Eddin » Sat Mar 24, 2018 1:59 pm
Using Windows 10 Pro 64-bit, with Audacity 2.2.2.
Sometimes, when I drag-and-drop a sample from FL Studio (using its default D&D) to Audacity, Audacity does not load the sample, does not show the "Audacity did not recognize the type of the file" message, and refuses to exit/close.
And when I try to import the same sample using any method in Audacity, Audacity crashes (sometimes with a debug report), and the same thing happens even after restarting Audacity.
A debug report:
Audacity_dbgrpt-5760-20180324T164012.zip
(132.45 KiB) Downloaded 9 times
Re: Bug(s) when D&D a sample from FL Studio to Audacity.
Post by steve » Mon Apr 02, 2018 12:16 pm
It looks like there is a problem with the file that you are trying to import. I'm not an expert at this, but it looks like Audacity is attempting to import a WAV file with libsndfile, which should work for a valid WAV file, but that fails, so Audacity then attempts to import the file with FFmpeg, but when FFmpeg tries, it crashes, and takes Audacity down with it.
As a workaround, perhaps you could export the sample from FL Studio as a WAV file (which will hopefully produce a valid WAV file), and then import that into Audacity.
Post by kozikowski » Tue Apr 03, 2018 12:02 am
As an experiment, does this dance work with any type of sound file even if you're not going to use it that way?
