Normalize maximum amplitude [SOLVED]
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
jim1001
Operating System: Windows 7
Post by jim1001 » Sun Mar 18, 2018 7:38 pm
The default setting for Normalize maximum amplitude in Audacity 2.2.1 is -1 dB. When I leave it at this I get a peak of -1 to +1 on the vertical scale.
However the manual page talks about bringing the peak up to 0 dB. This doesn't seem to tie up. Could it be made a bit clearer?
ps: is the Normalize maximum amplitude value referring to an absolute value? In which case should it be appended with a suffix?
Happy to get clarification - thanks.
Re: Normalize maximum amplitude
Post by steve » Sun Mar 18, 2018 8:33 pm
jim1001 wrote:The default setting for Normalize maximum amplitude in Audacity 2.2.1 is -1 dB. When I leave it at this I get a peak of -1 to +1 on the vertical scale.
If you look closely, the maximum peaks will be a little less than 1 (about +/- 0.9)
jim1001 wrote:However the manual page talks about bringing the peak up to 0 dB.
Please give a link and the exact quote.
jim1001 wrote: ps: is the Normalize maximum amplitude value referring to an absolute value? In which case should it be appended with a suffix?
As is common practice for signal processing, the full version would be "dBFS" (reference "full scale"). As is the convention in most audio applications, this is frequently abbreviated to "dB".
https://en.wikipedia.org/wiki/Decibel#Audio_electronics
https://en.wikipedia.org/wiki/DBFS
jim1001
Post by jim1001 » Sun Mar 18, 2018 10:24 pm
Thanks for reply.
Here's the quote from this section:
there are three ways to bring the peak up to 0 dB (+1.0 to -1.0 on the vertical scale).
"Normalize the maximum amplitude" to -0.0 dB
Thanks.
Post by steve » Sun Mar 18, 2018 11:52 pm
jim1001 wrote:there are three ways to bring the peak up to 0 dB (+1.0 to -1.0 on the vertical scale).
Yes, that's correct.
"Full scale" is 0 dB, which is the range +1 to -1 on a linear scale.
Before you complain, yes I know that it is confusing to represent amplitude as dB in some places and a 0 to 1 scale in others, but that a quirk of Audacity's history. ;)
To Normalize to 0 dB / full scale / 1.0 linear absolute, you would set the Normalize effect to normalize to 0.0 dB.
Usually it is best to retain a little headroom, which is why the default setting for Normalize is -1 dBFS.
Post by kozikowski » Mon Mar 19, 2018 12:21 am
I have a handy conversion chart.
Percent-dB_Conversion .png (11.48 KiB) Viewed 1847 times
Click the graphic to see the whole thing.
Convert Percent to Audacity by moving the point to the left. 50% is 0.5. That's half-way which works out to 6dB. That's the only one I remember in my head.
jim1001
Re: Normalize maximum amplitude [SOLVED]
Post by jim1001 » Mon Mar 19, 2018 10:27 am
Thanks both for your time & the very informative replies. I understand it now.
All the best,
Jim
