adding tracks is very cumbersome the way i presently do it. if i have a track open, then wish to add a second track to run sequentially, i open a second copy of audacity and add a track to it, copy the track, and then go back to the first track and paste it there. if i want to then add a third track, again i open another copy of audacity with the third track and then copy and paste it onto the first copy of audacity which has tracks number 1 and 2. if i want to add a fourth track, i again have to open it with a new copy of audacity, etc.
there must be a way to do add sequential tracks without all the opening, copying and pasting that i am doing. can someone tell me an easier way?
adding tracks
Re: adding tracks
Open all the tracks in one Audacity window, (e.g. drag'n'drop).jfkadlec wrote:there must be a way to do add sequential tracks without all the opening, copying and pasting that i am doing...
then choose to align tracks end to end
then choose mix and render.
Alternatively use Audacity's time shift tool to manually move all the open tracks onto one track ...
