Audacity-win-2.2.2.exe checksum match problem
pacman10
Post by pacman10 » Sun Mar 18, 2018 11:44 am
Windows 10. Downloaded audacity-win-2.2.2.exe from Fosshub today, noted the SHA256 signature, opened up the file Properties-File Hashes in Windows Explorer, and there it only shows CRC-32, MD5 and SHA-1 hash values. No sign of SHA256.
Is the SHA256 hash hidden somewhere else in the Windows Explorer file Properties ?
DVDdoug
Forum Crew
Re: Audacity-win-2.2.2.exe checksum match problem
Post by DVDdoug » Sun Mar 18, 2018 4:29 pm
This page has a link to a checksum calculator.
pacman10
Post by pacman10 » Sun Mar 18, 2018 4:51 pm
Thank you. I already tried the calculator but the Download page tells me to use SHA-256 and this calculator doesn't get me any further.
Post by steve » Sun Mar 18, 2018 9:18 pm
Direct link to the checker: https://md5file.com/calculator
Ensure that the option "SHA-256" is selected (click on picture below to expand):
pacman10
Post by pacman10 » Mon Mar 19, 2018 6:57 am
Thank you. I had already been there and done that but I think it's finally dawned on me that that calculator is producing a SHA-256 hash which the Windows Explorer Properties function can't or won't and that it is then up to me to compare the calculator-produced hash with the "signature" on the Fosshub site (I presume "signature" is the same as "hash") by going through the two visually and character-for-character (i.e. there's no simple two-slot system for matching the two hashes). Is that correct ?
