Tool bar recording volume slider locked
Help for Audacity on macOS.
dwayneill
Post by dwayneill » Wed Mar 14, 2018 4:11 pm
I get a notice "recording volume ( unavailable: use systems mixer) it was working previously. Have I clicked on something inadvertently? How to fix?
Re: Tool bar recording volume slider locked
Post by steve » Wed Mar 14, 2018 4:48 pm
Have you changed the recording device?
Some devices (notably USB devices) don't have software level control.
dwayneill
Post by dwayneill » Wed Mar 14, 2018 5:01 pm
I have been recording from a tape player connected directly to my Mac. I am new to audacity so I don't know where to go. It worked initially, using the aforementioned connection and also using my blue yeti microphone. I hate to have to download Audacity again. Is there a step by step procedure that I can go through to eliminate any erroneous settings?
billw58
Post by billw58 » Wed Mar 14, 2018 7:40 pm
dwayneill wrote:I have been recording from a tape player connected directly to my Mac. I am new to audacity so I don't know where to go. It worked initially, using the aforementioned connection and also using my blue yeti microphone. I hate to have to download Audacity again. Is there a step by step procedure that I can go through to eliminate any erroneous settings?
Don't download Audacity again - that won't help.
As Steve noted, you have probably set your recording device to a USB Audio CODEC. What is the selection for recording device in the Device Toolbar?
Have a look at this page.
-- Bill
