How to increase volume of portion of audio track?
Rickenbacker
Post by Rickenbacker » Sun Mar 11, 2018 2:45 pm
To sound as if someone is turning up the volume in the middle of a song. (I've got ver. 2.1.2)
Re: How to increase volume of portion of audio track?
Post by steve » Sun Mar 11, 2018 2:48 pm
You could try the "Envelope Tool" (http://manual.audacityteam.org/man/envelope_tool.html) but note that if the starting volume is too high, increasing the volume will cause distortion. Ensure that your track has sufficient "headroom" to allow the volume to be increased without distorting.
