Her's my issue:
Recording at one place with Windows 10, Audacity 2.2.2
Once recording is done, put session (with data file) on USB, went home to load it up and work on it (Windows 10, audacity 2.2.2)
Audacity crashed on loading if I tried to load off the USB. Copied data to desktop, still crashes. Load Audacity, then the file... still crashes.
Went back to recording site, saved project to usb, tried again, failure.
I have to record at site A and work at site B. Solutions?
Thanks in advanced.
Audacity Crashes while loading
