Bug: Settings dialogue not readable with dark MATE theme
Please state:
Minty18
Post by Minty18 » Sat Mar 10, 2018 2:42 pm
System-info first:
Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0) Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Audacity 2.2.2 from PPA
This morning I tried Audacity 2.2.2 but had to remove it again.
It really has nice GUI themes now. But:
I use a dark overall theme (Mint-Y-Dark or Vertex Dark) which has white font on dark background.
The trouble with Audacity's setting stuff is, that the white font is set on a white background ... thus unreadable. What a pity.
My suggestion to the programmers: take font and background from the user's theme and everything should be fine.
Hopefully this can be fixed ... else I'll have to stay on old versions where this problem doesn't occur.
Yours
Minty18
Re: Bug: Settings dialogue not readable with dark MATE theme
Post by steve » Sat Apr 07, 2018 3:21 pm
Does the problem occur with all of Audacity's them options? http://manual.audacityteam.org/man/themes.html
Also, have you tried toggling the option: "Blend system and Audacity theme"? http://manual.audacityteam.org/man/inte ... ences.html
(Note that to fully refresh changed theme settings requires restarting Audacity)
Minty18
Post by Minty18 » Sun Apr 08, 2018 8:38 am
Changing the Theme doesn't seem to have an effect in that place, nor does the blending option.
I have restarted audacity after each change.
May I attach screenshots here?
This problem did not occur in the previous versions of audacity (I'm running 2.1.2 at the moment)
Preferences_ Interface_003.png (45.51 KiB) Viewed 1061 times
Preferences_ Interface_005.png (45.51 KiB) Viewed 1061 times
Post by steve » Sun Apr 08, 2018 10:41 am
OK, I see the problem - Theme background colour is not currently defined for the scrollers in Preferences. I suspect this is an oversight and looks to be an easy fix.
Post by steve » Sun Apr 08, 2018 6:13 pm
I've now committed a fix, which will be in the next release.
Minty18
Post by Minty18 » Sun Apr 08, 2018 7:49 pm
Thank you. I'm looking forward to he next release.
