Keeps on saying failed to register when hit ok after enable of \ladspa-util.dll
So there's no solution to this yet for Windows10 64?
I notice there's a ton of new add ons I hadn't enabled before or after this install, but not sure if they were part of it or not, though they were in the new folder.
Problem with re-enabling plug-ins since upgrade to 2.2.2
