- Download the ZIP version of Audacity 2.3.0 from: https://www.audacityteam.org/download/windows/
- Extract the ZIP archive somewhere convenient (for example, you "Documents" folder)
- Open the extracted folder and you should see a file called "audacity.exe", some other files and some other folders.
Create a new folder in the same location as the "audacity.exe" file, and name the new folder "Portable Settings". - Create a Desktop link to "audacity.exe"
- Double click on the Desktop link to launch Audacity.
You should see the "Welcome" screen. - DO NOT add any plug-ins to this version of Audacity at this stage. Just try using it and check if it is working correctly and let us know the result.
Problem with re-enabling plug-ins since upgrade to 2.2.2
Re: Problem with re-enabling plug-ins since upgrade to 2.2.2
Something for you all to try:
lespaulplayer621
I think that I have found some kind of solution for that problem with plugins in Audacity version 2.2.2 and 2.3.0. So my workaround for this issue was just making reinstallation of operating system from a usb drive.
I did this because I was suffering from other some weird issues on my PC for which I couldn't identify the cause. My OS is Windows 10 and I created an installing drive of that system on my usb pendrive and then I performed reinstallation of it. After that I installed Audacity version 2.3.0 on my PC and pasted some vst plugin files, which are supported by Audacity, to the default directory for plugins in this program. Then I opened Audacity, entered into plugin manager, chose some newly installed plugins and confirm my selections. Surprisingly, I noticed that everything was working COMPLETLY WELL! I didn't receive any notification about any kind of errors or anything like that.
I know that my solution isn't the most elegant way for dealing with that problem, but it was effective (at least for me). So maybe the real cause of that problem with plugins in recent versions of Audacity is not on the side of the program itself, but rather on the side of OS installed on a computer. I don't really know, maybe the developers of Audacity will know more about that. But as I said before, for me the problem is SOLVED.
That's a rather drastic solution, but I had to do the same recently on a Windows 10 machine because a failed Windows update totally trashed its ability to boot up. Pleased to hear it is now working for you. Thanks for letting us know.lespaulplayer621 wrote: ↑Mon Oct 22, 2018 2:03 pmSo my workaround for this issue was just making reinstallation of operating system from a usb drive.
LivingInternet
Fwiw, I too found this problem. I installed 2.2.2 on a new machine, and added several new plugins. When I went to enable them, I got this error with (as I recall fairly accurately but did not record so might not be 100% right) Marvel GEQ and Ozone Imager.
Just now added Sibilance CM (thread here) and got the following error.
As usual I expect it will work anyway. But of course there is a concern there will be problem, perhaps quality issues, and I won't find out about them until later. So would be nice to track down and resolve, if only for 2.3.X.
lespaulplayer621 wrote in this post that the problem is solved for him: viewtopic.php?p=356489#p356489karimovic wrote: ↑Mon Oct 29, 2018 7:00 pmwhat is the version of udacity you installlespaulplayer621 wrote: ↑Mon Mar 05, 2018 4:48 pmI have EXACTLY THE SAME issue. Whenever I'm trying to load my plugins, which works perfectly well in previous versions of Audacity, this error message occurs.
But there is one interesting thing - when I load every plugin that I want to use and close the error messages, I can use those plugins without any problem. So this error is a little bit weird.
I also wrote to the Audacity feedback contact email and I wonder what they will reply to me.
yeah thank you dude !Satamanster wrote: ↑Wed Mar 14, 2018 2:59 amOk so I am a windows user and I installed audacity today. I never before tried to use any plugins but I decided to give it a go and voila... Getting the same error as you were guys. But then it hit me.. "Failed to register".. Hmmm... Shutdown audacity... Deep Breath... run audacity as ADMINISTRATOR.... And tcharaaan... IT WORKS NOW! NO anoying errors.
thelearningtech
why don't you try re-install it . Or check for any updates.
Did you read the topic before posting your reply? lespaulplayer621 wrote in this post that the problem is solved for him: viewtopic.php?p=356489#p356489thelearningtech wrote: ↑Wed Oct 31, 2018 5:30 pmwhy don't you try re-install it . Or check for any updates.
Here is the solution.
Everyone that is having problems is downloading the 64 bit version of the addon. but in fact Audacity is only available in the 64 bit version for Linux. So all you need to do is go back and download the 32 bit version of Gsnap or whatever it is you are trying to load and it should work just fine..
That is not the problem described in this thread. They are talking about reinstalling the plug-ins that they were using successfully in a previous version of Audacity. The problem was reported as solved in this post: viewtopic.php?p=356489#p356489davis422 wrote: ↑Thu Jan 10, 2019 4:21 amHere is the solution.
