Linear Mono
rj7500
Linear Mono
Post by rj7500 » Thu Feb 22, 2018 8:23 pm
Hi
Just got a request for files to be exported in linear mono 16b PCM 8hz.
Can that be done with Audacity 2.2.1?
Thanks in advance
Bob H
Re: Linear Mono
Post by steve » Thu Feb 22, 2018 8:52 pm
Sounds to me like regular "16-bit WAV", 8 kHz sample rate, mono.
Yes you can do that with Audacity 2.2.1, but upgrading to 2.2.2 at your earliest convenience is highly recommended as the new version has some important bug fixes.
First you need to ensure that your track is mono. If you have a stereo track, you can mix it to mono:
Select the track (click on it), then
"Tracks menu > Mix > Mix Stereo to Mono"
http://manual.audacityteam.org/man/tracks_menu_mix.html
Second, set the "Project Rate" to 8000 (bottom left corner of the main window.
http://manual.audacityteam.org/man/sele ... .html#rate
Then export as 16-bit WAV ("File menu > Export > Export as WAV")
I presume that they have good reason for this format?
Generally, if a smaller file is required, it's better to use a compressed format such as MP3 or OGG rather than reducing the sample rate to 8000, but perhaps they have a reason.
rj7500
Re: Linear Mono
Post by rj7500 » Thu Feb 22, 2018 8:54 pm
Thanks Buanzo...........always a pleasure dealing with you folks.
I will upgrade today
Bob H
Trebor
Re: Linear Mono
Post by Trebor » Thu Feb 22, 2018 9:15 pm
rj7500 wrote:... files to be exported in linear mono 16b PCM 8hz.
That excludes µ-law & A-law, which employ a compander ...
I think WAV PCM format is "linear", (i.e. LPCM).
rj7500
Re: Linear Mono
Post by rj7500 » Thu Feb 22, 2018 9:19 pm
Right Trebor
Check out Buanzo's reply.
Bob H
Trebor
Re: Linear Mono
Post by Trebor » Thu Feb 22, 2018 9:29 pm
rj7500 wrote:Check out Buanzo's reply.
Steve ≠ Buanzo . ( Buanzo = Arturo Busleiman ).
Re: Linear Mono
Post by steve » Fri Feb 23, 2018 10:49 am
For information, I'm not Buanzo. I'm Steve, and I'm the forum administrator (and regular forum contributor). Buanzo is the "System Administrator".
Email notifications are addressed as from Buanzo, as he configured and maintains the web-server side of the forum software, though he is not involved in the day to day running of the forum.
rj7500
Re: Linear Mono
Post by rj7500 » Fri Feb 23, 2018 3:37 pm
Ok Steve....thanks for putting me straight.
