member for years, knew the program
suttlemyre
Post by suttlemyre » Sun Feb 18, 2018 4:25 am
ole dell bown out, audio box usb. condensers mikes bought a high dolllsr hp laptop,newversion of window 10, it hill noth let me ass 2nd or thirtd track, what am I doinf wrong, suttlemyre
suttlemyre
Re: member for years, knew the program
Post by suttlemyre » Sun Feb 18, 2018 6:10 am
will not mix and render, either.do I need to reinstal
Trebor
Post by Trebor » Sun Feb 18, 2018 6:18 am
suttlemyre wrote:... it hill noth let me ass 2nd or thirtd track, what am I doinf wrong...
The default setting on Audacity 2-2-0 & later is that it appends recordings, rather than creating a new track every-time you start a new recording, (which was what happened in older versions of Audacity).
Press "shift" & press record to start recording on a new track, (rather than appending).
waxcylinder
Post by waxcylinder » Sun Feb 18, 2018 9:54 am
Or if you prefer the old behavior where the default is always record on a new track
just go to Edit > Preferences and choose the Recording tab and check on the box for Always record on a new track
suttlemyre
Post by suttlemyre » Sun Feb 18, 2018 3:10 pm
got it thanks
HalfNote5
Post by HalfNote5 » Sun Feb 18, 2018 4:10 pm
waxcylinder wrote:Or if you prefer the old behavior where the default is always record on a new track
THIS is how you handle a change in defaults like that. The Shift option is nice, but it's great to be able to adjust default behavior. = )
waxcylinder
Post by waxcylinder » Sun Feb 18, 2018 4:48 pm
Glad you approve 8-)
We turned it around to make it easier for newbies - but when we do that we try to make it possible to revert to the older more complex behavior (another good example is the behavior of the Solo button).
