[email protected]
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
[email protected]
before the time it works well but now is just a crap. see the screenshot for details. (when clicking Play or starting at the terminal)
- Attachments
- snapshot1.png (68.59 KiB) Viewed 632 times
- snapshot2.png (63.8 KiB) Viewed 633 times
- snapshot3.png (30.77 KiB) Viewed 632 times
Re: [email protected]
Are you using the default Ubuntu build? It's known to be buggy. I gave up on it and built Audacity 1.3.7 from the source code, and it works far better.
There is now a better solution. I've just updated Ubuntu to 9.04 and Audacity works great. In fact, I decided to be a bit ambitious and installed the real time kernel from Ubuntu Studio, and now it even works with Jack.
I would strongly recommend that you upgrade Audacity to a more recent version, though which route you take is a matter of your preference.
