Audacity flush cache
edwinn
Operating System: Windows 7
Post by edwinn » Sun Feb 11, 2018 6:15 pm
Does Audacity keep data in cache or temp file when all audio windows have been closed after editing? which I image it does, and is there a way to FLUSH cache/temp file without having to close and restart Audacity?
I'm posting this question at risk of being seen as a dummy.
-Ed
Trebor
Re: Audacity flush cache
Post by Trebor » Sun Feb 11, 2018 7:20 pm
edwinn wrote:Does Audacity keep data in cache or temp file when all audio windows have been closed after editing?
Audacity only keeps a copy if it crashes, otherwise it's automatically deleted when Audacity is closed.
In windows it's stored here ...
Code: Select all
C:\Users\<YourNameHere>\AppData\Roaming\Audacity\AutoSave
Personally I would not delete anything from that "AutoSave" folder while Audacity was open.
edwinn
Post by edwinn » Sun Feb 11, 2018 8:44 pm
Trebor wrote: Audacity only keeps a copy if it crashes, otherwise it's automatically deleted when Audacity is closed.
Code: Select all
Thanks, that's handy folder to make note of.
I was referring to `undo´ data... what are they called? au files?
So now the question is, how to clear Audacity Undo and AutoSave data, as if you closed the program and restarted it.
-Ed
Trebor
Post by Trebor » Sun Feb 11, 2018 11:07 pm
edwinn wrote:I was referring to `undo´ data...
You can "discard" part/all of the `undo´ data from "History" ...
http://ttmanual.audacityteam.org/man/Un ... ry#Discard
