Reverting to earlier version
jethroburns
Help please. I updated my version of Audacity yesterday and I find the new version terribly confusing. Whereas before I used to have to outline items (turn them grey) to work on them, everything is grey now and when I highlight them they turn white. When click the record button to overdub it just carried on recording on the same track. I have to use a couple of keys to get it to overdub. Most confusing of alll is when I click "solo" to hear just one track, as soon as I turn it off everything is turned on (including items that I muted rather than deleting them).
So is there a way of returning to my earlier version?
Anton
Anton
waxcylinder
Re: Reverting to earlier version
If you prefer the older traditional Audacity appearance, just go to Edit>Preferences and select the Interface tab.jethroburns wrote: Whereas before I used to have to outline items (turn them grey) to work on them, everything is grey now and when I highlight them they turn white.
And there click on the Theme dropdown and select Classic.
We turned this (default) behavior around a couple of releases ago as it was confusing a lot of users when record always started a new track.jethroburns wrote: When click the record button to overdub it just carried on recording on the same track. I have to use a couple of keys to get it to overdub.
If you want to rever to the old behavior, just go to Edit>Preferences and select the Recording tab.
On that dialog pane check on the "Always record on a new track"
I'm no expert on Solo and Mute as I rarely use those functions - I do recall that we "simplified" the default behavior a while back - and there is another more complex setting that may suit youjethroburns wrote:Most confusing of alll is when I click "solo" to hear just one track, as soon as I turn it off everything is turned on (including items that I muted rather than deleting them).
See: https://manual.audacityteam.org/man/tra ... ences.html
I suspect you want the Multi-track option.
This, more complicated, setting was the default in earlier versions of Audacity.
waxcylinder
And with those three preferences changes you should find Audacity looking and behaving as you are used to.
With no need to revert to an earlier version (doing so would lose the advantage of the many bug-fixes).
jethroburns
Thanks very much for all your answers.
One last question. I came back to this forum to see if there were any replies and could not see any so had go through my history to find my post and your answers. Is there a simpler way of doing this?
Anton
Anton
waxcylinder
At the bottom of the thread there is a "Subscribe topic" button for the particular thread - click on that and you will get email notifications of updates to the thread.
jethroburns
Thank you so much everyone. I tried out all your recommendations and it now works fine. Yesterday evening I was in despair, as I could not understand what was going on.
The solo button is particularly useful when do vocal harmonises, ...
Best regards,
Anton
Best regards,
Anton
waxcylinder
What we've tried to do in recent releases is to make things simpler and more straightforward for the naive or infrequent user.
This has meant in many cases "hiding away" older more complex behaviors in user-settable preferences.
We are currently working on a plan to remove several bear traps that we know about in the app that catch folk out.
We've fixed on of them for the upcoming 2.2.2 release, relating to vertical zoom that a lot of folk got stuck in:
https://alphamanual.audacityteam.org/ma ... ease#vzoom
This change will turn that off by default - but it can be re-enabled.
This is the bear-trap planning page on our Wiki: https://wiki.audacityteam.org/wiki/ToDo ... _a_Mode%27
jethroburns
Well, I am a naive but frequent user, using it to producer multitrack recordings of my music. But I tend to panic when things change out of my comfort zone.
Anton
Anton
