Export does not work
frosty
Post by frosty » Fri Oct 12, 2007 8:18 pm
I'm a new user of Audacity... can't get export to work. Got the audio in ok, and labelled tracks. Select "export to FLAC" and get an error message like : "unable to export audio to ... path/fn". Doesn't seem to matter what directory I try to write to, still get this message. Export to WAV works fine. Any clues where am I going wrong?
Re: Export does not work
Post by kozikowski » Fri Oct 12, 2007 10:01 pm
None of my Audacities have "Export to FLAC.."
How did you do that? What Audacity version are you using?
frosty
Post by frosty » Sat Oct 13, 2007 12:10 am
further research tells me that the current stable version has export flac as an option, but it is not working. The beta code version says it is supposed to not only be an option... but also work!
Post by kozikowski » Sat Oct 13, 2007 5:32 am
FLAC isn't a default export format. You had to enable it from Preferences, File Formats.
Yes, it doesn't work on Windows machines unless you recompile it from the source code. Or jump to Beta version 1.3.
