recording levels, cannot change
Help for Audacity on macOS.
Re: recording levels, cannot change
Post by kozikowski » Tue Jan 30, 2018 1:52 am
Oh, I corrected your fluff.
Post by kozikowski » Tue Jan 30, 2018 1:59 am
You have a hummmmm in your background sound. It's 120Hz and I got rid of it with an extra processing step before Mastering. The show sounds the same and passes noise with a comfortable margin now.
So we're done.
Ideally, we'll find something in the room with you is creating this hum sound and you can turn it off during recording. Un-ideally, it will turn out to be the computer.
As we go.
Post by kozikowski » Tue Jan 30, 2018 2:06 am
This is your raw submission with the Room Tone segment at the front boosted. Nobody cares about the ffffffffff rain in the trees sound, but there's a mmmmmmmm in there, too. That's the one making it hard to hit audiobook noise. Is there a fridge in with you? Air Conditioning?
What's the computer and how far away is it?
test HagoodHumBoost.wav
(498.7 KiB) Downloaded 11 times
