recording levels, cannot change
Help for Audacity on macOS.
NilaB
Post by NilaB » Fri Jan 26, 2018 3:54 pm
Desperate for assistance. I have been through every tutorial, video, etc. and checked all the Audacity recommended preferences, and still when I hit record, it starts at -60. Playback is fine. The gain is adjusted so that the input level passes. 23 files just returned for low volumes, I have to find a way to change this (I have soooo many hours already into these projects), so: 1) How can I fix the files without re-recording them, and 2) How can I change the floor so that it starts recording at 0? Help please please please....
Nila
Re: recording levels, cannot change
Post by kozikowski » Fri Jan 26, 2018 4:32 pm
Rather than guessing at it from multiple time zones away, record a simple 20 second voice test and post it here on the forum.
http://www.kozco.com/tech/audacity/Test ... _Clip.html
Don't process anything. Just record, stop and export a WAV sound file. Follow the details in that instruction. Don't make it too short, either. Talk the full 16 to 18 seconds. Which words aren't important. Read the breakfast cereal box.
Post by kozikowski » Sat Jan 27, 2018 2:30 am
Are you talking about the blue waves?
Screen Shot 2018-01-26 at 18.24.22.png (5.65 KiB) Viewed 678 times
You can have a broken microphone and have a flat line that settles somewhere other than zero.
I don't have a very good picture of this.
Screen Shot 2018-01-26 at 18.27.31.png (113.66 KiB) Viewed 678 times
Is this what you have? I don't understand the complaint.
NilaB
Post by NilaB » Sat Jan 27, 2018 9:22 pm
test Hagood.mp3
Per instructions
(493.47 KiB) Downloaded 30 times
Screen Shot 2018-01-27 at 1.17.17 PM.png (72.18 KiB) Viewed 661 times
This is the default I get when I press record
waxcylinder
Post by waxcylinder » Sun Jan 28, 2018 10:26 am
You are stuck in Scrub mode - just press the Stop button and then you should be able to record.
To avoid this happening again get rid of the Scrub Ruler (the gray horizontal bar under the Timeline). Just right click in the bar and uncheck "Scrub Ruler"
See this page in the Manual about Scrubbing: https://manual.audacityteam.org/man/scr ... eking.html
NilaB
Post by NilaB » Sun Jan 28, 2018 3:17 pm
Screen Shot 2018-01-28 at 7.16.25 AM.png (64.69 KiB) Viewed 650 times
That had no effect on the problem. any other suggestions?
NilaB
Post by NilaB » Sun Jan 28, 2018 3:59 pm
test Hagood.mp3
(493.47 KiB) Downloaded 27 times
this is the test you asked for
NilaB
Post by NilaB » Sun Jan 28, 2018 6:43 pm
I may have found the problem, it is not Audacity at all, it's my FRIGGIN' iMAC DESKTOP!!!! It appears I have to re-format my whole effing hard drive and reinstall the operating system!!! :evil:
NilaB
Post by NilaB » Mon Jan 29, 2018 2:26 pm
Not the Mac after all, back to being stumped. Maybe the microphone?
Post by kozikowski » Tue Jan 30, 2018 1:51 am
One at a time.
I ran your submission through the AudioBook Mastering Suite and it passes. Top three values and sentence 2/3 down.
Screen Shot 2018-01-29 at 17.43.22.png (42.56 KiB) Viewed 616 times
There's not a lot of room to be sloppy, but there's nothing wrong with this clip.
Use the drop-down menu to the left of the blue waves and select Waveform. Not Waveform (dB).
That will give you the display the rest of us are seeing.
Screen Shot 2018-01-29 at 17.46.59.png (12.71 KiB) Viewed 616 times
If that's typical of your presentation, your room has slightly too much background noise and I can't tell why yet. If that's just the way it is, I can talk you through gentle noise reduction and the work should be out the door safe.
As we go.
test HagoodMastered.wav
(1.82 MiB) Downloaded 25 times
