hahaha
as a starter I added entries for Solo, Mute, Pan and gain in the Index as sub-entries under the pre-existing Track Control Panel entry
GOOD catch Winwhbjr wrote:Um, yes, but... The index entry for "Track Control Panel - Solo Button" goes to the right place, the Solo section of the Tracks page. But on that page: "There are two other options for Solo button behavior in the Tracks Preferences." That link goes to the top of the Track Preferences page, which does not have a text-based link to Solo (i.e, searching that page for the word "solo" comes up empty). It really should go to the Tracks Behaviors Preferences page, and to be really helpful, there should be a tag on the Solo section at the bottom of that page, so that a "#Solo_Button" tag would work.
Unless I've missed something, this is the only item (in this scope) which deserves this special treatment; the Mute, Pan and Gain elements do not have any Preferences attached to them.
It's possible that I'm asking for too much, and I completely understand if that's true. All I know is, I'm stumbling through the documentation, and it's currently non-trivial to find what I'm looking for.
I've fixed that and I did as you asked and added an anchor for "Solo" on the Tracks Behaviors Prefs page - but because the Solo section is right at the bottom of the page it showas a lot of other stuff above it. I'm thinking it may look better to just link to the top of the page (where the dialog is seen showing Solo - and you can search for the text "Solo").
See what you think ...
Peter
