Noise Floor Woes/ Mastering for Audiobook Help!
Help for Audacity on macOS.
Re: Noise Floor Woes/ Mastering for Audiobook Help!
Post by kozikowski » Sat Jan 27, 2018 8:00 pm
How much of that noise is below 20Hz? Home recording microphones can have stunningly high sub-sonic noise, and it can throw off noise measurements.
Trebor
Post by Trebor » Sat Jan 27, 2018 9:04 pm
kozikowski wrote:How much of that noise is below 20Hz?
audiosample before-after notches (highest resolution spectrogram).png (180.42 KiB) Viewed 167 times
[/url]
