should i switch to ubuntu ? or other distro.
Please state:
joe sixpak
Post by joe sixpak » Sun Jan 21, 2018 11:53 pm
I am currently using windoze 8.1 with some occasional problems.
I am wondering if some linux distro would work better with audacity?
If you have tried both I would appreciate hearing your views concerning reliability especially wrt interference from opsys or program popup messages.
Re: should i switch to ubuntu ? or other distro.
Post by steve » Mon Jan 22, 2018 1:23 pm
There are "many" different flavours of Linux, which are called "distributions".
If you're new to Linux it's a good idea to start with a popular distribution that updates regularly and is widely used. Popular distributions such as Ubuntu and Mint have large user communities, which makes life much easier if you encounter problems.
Before deciding which distribution to install, you can "test drive" many distributions by running a "Live CD" (https://linux.co.uk/pages/livecd/)
Testing of Audacity on Linux by the Audacity team is primarily done on Ubuntu or one of its derivatives (such as Mint). Ubuntu is available in several different versions. I am currently using Xubuntu, which I've been using for the last few years, and I like it a lot, and bar a couple of minor glitches it is rock solid reliable. There's no such thing as "the best distribution", as it largely comes down to personal preference.
joe sixpak
Post by joe sixpak » Fri Jan 26, 2018 5:47 am
steve wrote:There are "many" different flavours of Linux, which are called "distributions".
Thanks.
I am going to use ubuntu for other purposes.
Just wondered if anyone had better luck with their linux flavored distro than with windoze.
I would be willing to use any distro if it would work better.
nesrad
Operating System: OS X 10.7 - 10.8 Lion / Mountain Lion
Post by nesrad » Fri Jan 26, 2018 3:58 pm
What's not working to your liking in Windows? For a regular user, functionality in Windows is equal to Linux. Where Linux really shines is for power users and programmers. But you can do both and try for yourself. Why not give it a try on a separate partition? A nice distribution is Linux Mint. It's built on Ubuntu but it's slightly easier to set up.
autodctr
Post by autodctr » Sat Feb 03, 2018 12:57 am
I use Xubuntu. Ubuntu, Xubuntu, Lubuntu (and others) all use the same kernel and can run all of the same programs. The difference is the desktop. If you really like fancy desktops, then Ubuntu is for you. Just keep in mind that the fancier the desktop the less memory for running programs. Xubuntu is quite simple and uses quite a bit less memory. Lubuntu uses even less, but (in my opinion) really bland.
