ACX Check not working
Help for Audacity on macOS.
Kristina Lawson
Post by Kristina Lawson » Sun Jan 21, 2018 4:41 pm
I have followed all the directions online for using ACX Check and can't seem to find it in Audacity.
I am using Audacity 2.2.1 with MacOS High Sierra Version 10.13.2
The link on the wiki page led me to download Acx-check.ny.txt.
On the computer I have dropped this into:
Library>Application Support>audacity>plug-ins
Then I go to Audacity:
Add/Remove Plug-ins...
But do not see ACX Check anywhere. I am very confused because all of the directions on multiple sites say this is how you do it. At my wits end. I'm already in the process of creating my first audiobook and am worried all the work will be denied by ACX if this isn't fixed. Thanks for any help.
Re: ACX Check not working
Post by kozikowski » Sun Jan 21, 2018 4:54 pm
Can you point me to that link?
The download is a Nyquist Program not a plain text file. Remove the .txt from the end of the file and try again.
Also, It appears under Analyze in Audacity, not Effect.
Only the first three analysis lines and sentence 2/3 down are used in ACX submissions and it's highly recommended you do your work in Mono (one blue wave) instead of Stereo.
Everybody fails Noise and Noise Reduction is not always the answer. ACX has a failure they call Overprocessing where you passed ACX Check by appying too many effects. The goal is to sound natural.
Post by kozikowski » Sun Jan 21, 2018 5:21 pm
This is what a successful ACX Check panel looks like.
If your submission fails, the panel will give you simple comments about the failure.
You can confuse the app. ACX Check looks for at least 1/2 second of clean Room Tone to measure noise. If it doesn't find any, it takes the closest it can get and very likely fail you even though the performance may actually be OK.
Room Tone is what the room sounds like when you stop talking. Do Not make mouth noises or shuffle in your seat or make other unconscious noises. They will all fail a noise test. I tell people freeze and hold your breath for about a second.
ACX requires portions of Room Tone in your submissions, so you will need to get good at this no matter what else happens.
Kristina Lawson
Post by Kristina Lawson » Sun Jan 21, 2018 6:20 pm
Yes, I have gone to "Analyze" to add the plug-in. It's not there.
Both of these links send you to a .txt file, not a .ny file.
http://wiki.audacityteam.org/wiki/Nyqui ... #ACX_Check
http://wiki.audacityteam.org/wiki/File:Acx-check.ny
I have tried deleting the .txt from the end of the files and it just comes back.
Does anyone have a link that will work?
Post by kozikowski » Sun Jan 21, 2018 6:39 pm
Fascinating. It's been something of a mystery where that .txt thing is coming from.
Attached.
See if that changes into a .txt file when you manage it.
I have a 10.11 Mac I can see what happens to me.
Acx-check.ny
(9.33 KiB) Downloaded 368 times
Kristina Lawson
Post by Kristina Lawson » Sun Jan 21, 2018 6:44 pm
kozikowski, you're the best :) That attachment worked perfectly.
Now I just need to figure out how to fix the issues that aren't a passing grade.
Post by kozikowski » Sun Jan 21, 2018 6:48 pm
Or, you can post a simple sound test and let us help.
http://www.kozco.com/tech/audacity/Test ... _Clip.html
Record it, export and post it. Don't help.
Post by kozikowski » Sun Jan 21, 2018 6:55 pm
Now we need to do two things at once. I just downloaded the Acx-check.ny plugin to my desktop and it arrived in good working order. OS-X 10.11.6 El Capitan
Screen Shot 2018-01-21 at 10.50.28.png (25.98 KiB) Viewed 1423 times
Where do you download things to?
Post by kozikowski » Sun Jan 21, 2018 7:13 pm
Were you using Safari browser?
Kristina Lawson
Post by Kristina Lawson » Sun Jan 21, 2018 7:19 pm
Yes I was using Safari. I'm guessing that's the problem?
