Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fatima al ajhory
- Operating System: Windows 8 or 8.1
Post
by fatima al ajhory » Sun Jan 21, 2018 2:12 am
hello there i have a very annoying issue with audacity projects ive saved on my PC and urgently i want your help in that case every time i tried to reopen my saved projects i got a pop up message says " this program can't start because wxmsw30u_qa_vc_custom.dll is missing from your computer. try reinstalling thr program to fix this problem
Audacity
- i'm desperate
- my screenshot.png (156.52 KiB) Viewed 334 times
waxcylinder
Post
by waxcylinder » Sun Jan 21, 2018 3:31 pm
Have you tried, as the error message suggests, re-installing the Audacity app.
The latest version is 2.2.1 - and you can get it from here:
Update: I just checked my installation of 2.2.1 on my W10 laptop and that dll certainly comes as part of the download.
- 2.2.1 files.png (103.09 KiB) Viewed 318 times
joe sixpak
Post
by joe sixpak » Sun Jan 21, 2018 5:57 pm
I usually google for the driver, download and install it, to fix such problems.
Win 10 is supposed to do that automatically but if not then just DIY.
Post
by kozikowski » Sun Jan 21, 2018 7:46 pm
It is a little odd when it fails.....
Virus software?
