I have been wanting to make my recorded voice sound acoustic. I have seen videos on youtube, which had the 'acoustic' preset all ready loaded under EQ. I've been searching for this preset online, & haven't been able to find it anywhere. I believe it's a .xml file, correct? Does anyone know where I can go to download it? Or, can someone send it to me via email? Or, tell me what settings to use in EQ to create this type of sound?
Thanks for all your help.
Effects For Audacity 2.2.1
josephwalking
Re: Effects For Audacity 2.2.1
Was it an ad for that software?which had the 'acoustic' preset all ready loaded under EQ.
Is this an ad for that software?
Unless you can run down the supplier, this isn't an Audacity problem.
There's a preset in Audacity's equalizer called "acoustic" ....josephwalking wrote: I have seen videos on youtube, which had the 'acoustic' preset all ready loaded under EQ.
josephwalking
I don't know, Koz. I just seen it. I'm not too familiar w/ Audacity as of yet.kozikowski wrote:Was it an ad for that software?which had the 'acoustic' preset all ready loaded under EQ.
It's not one of the presets that is shipped by default.Trebor wrote:There's a preset in Audacity's equalizer called "acoustic" ....
