intermittent background noise
ensportstimes
Re: intermittent background noise
Post by ensportstimes » Mon Jan 20, 2020 5:42 pm
Removing noise after you have recorded
  • Select the “silent” section of your audio, where it’s just noise.
    Go to the Effects menu and click Noise Removal.
    Click Get Noise Profile.
    Select all of the audio from which you want that background noise removed.
    Adjust the settings if necessary (defaults are fine) and click OK.
    Listen to ensure your audio doesn’t sound like it’s underwater.
For more information: https://theaudacitytopodcast.com/tap012 ... -audacity/
Thanks
Ensportstimes
[Advertizing deleted]
