When exporting a file as "M4A (AAC)," and using it in projects with AVIdemux, MKVToolNix, ConvertXtoDVD, Corel Video Studio and others, I experience a variety of problems, like audio delay or audio loss in an appended file when concatenating video files (I even renamed the file's extension from M4A to AAC). But when I recode the same exported file as an AAC in XMediaRecode, I experience no such issues.
Does FFmpeg AAC support render true AAC?
Is M4A truly AAC?
Re: Is M4A truly AAC?
Here are the details of an M4A (stereo) test file that I made just now:
Code: Select all
General
Complete name : ..../Desktop/untitled.m4a
Format : MPEG-4
Format profile : Apple audio with iTunes info
Codec ID : M4A (isom/iso2)
File size : 239 KiB
Duration : 9s 985ms
Overall bit rate mode : Constant
Overall bit rate : 196 Kbps
Encoded date : UTC 1904-01-01 00:00:00
Tagged date : UTC 1904-01-01 00:00:00
Writing application : Lavf56.40.101
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 9s 985ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 239 KiB (100%)
Default : Yes
Alternate group : 1
