How do I add a silence of (X time) when combining tracks?
Please state:
seru1
Post by seru1 » Fri Jan 12, 2018 8:54 pm
Kubuntu: 17.10
Audacity 2.1.2
I want to combine like 20 tracks together with a silence of 1.5 seconds between them, can anyone help me achieve this?
Can you outline the steps from scratch because i'm a real newbie?
Re: How do I add a silence of (X time) when combining tracks
Post by steve » Sat Jan 13, 2018 11:33 am
Assuming that you are starting with a fresh empty Audacity project and 20 audio files all in the same directory:
1) "File menu > Import > Audio" and select all of the files that you want to import.
The files will be imported as separate tracks.
2) Put the tracks in order by dragging them up / down (click on an empty part of the panel on the left end of the track and drag up/down. Take care not to click on the buttons or sliders).
3) "Ctrl + A" to select all
(if step 4 is not available in 2.1.1, skip to step 5)
4) "Tracks > Align Tracks > Align end to end" (http://manual.audacityteam.org/man/trac ... end_to_end)
5) Use the Time Shift tool to nudge each of the audio clips to the right so that you have the required gaps.
6) File > Export > Audio
Trebor
Post by Trebor » Sat Jan 13, 2018 12:59 pm
Could add 1.5 seconds of silence to all the tracks in one step, (once they are imported),
Then align end to end. Thus avoiding 20 usages of time-shift to create the silent gaps.
seru1
Post by seru1 » Sat Jan 13, 2018 1:42 pm
Thanks steve and trebor, so helpful, instant reply!
trebor, how will your list of steps look? is it a quicker way than steve's?
Trebor
Post by Trebor » Sat Jan 13, 2018 7:59 pm
seru1 wrote:trebor, how will your list of steps look? is it a quicker way than steve's?
Once all are imported, Select all the tracks,("Ctrl"+"A"), move the cursor to the start, ("J"),
then generate the silence which will be added to all the tracks ...
silence added to the start of all tracks at once, then aligned end-to-end.gif
silence added to the start of all tracks at once, then aligned end-to-end.gif (739.28 KiB) Viewed 882 times
seru1
Post by seru1 » Sat Jan 13, 2018 8:05 pm
this is amazing. I'm so happy, thank you both!!!
