Is there an equivalent for StereoMix in Win 10
hannibalstgt
Post by hannibalstgt » Mon Jan 08, 2018 5:37 pm
Hello,
under Windows 10 there seems to be no StereoMix . Is there an equivalent.
I want to save the sound of a mediafile played with Videolan. Drivers are Realtek High Definition Audio.
Currently this is only possible via a microphone.
Wolfgang
Trebor
Re: Is there an equivalent for StereoMix in Win 10
Post by Trebor » Mon Jan 08, 2018 6:41 pm
hannibalstgt wrote:under Windows 10 there seems to be no SteroMix . Is there an equivalent.
StereoMix may be hidden, here's how to see if you have it ...
http://www.thewindowsclub.com/how-to-en ... in-windows
If you don't have StereoMix, use Audacity's WASAPI option to record the computer sound ...
http://manual.audacityteam.org/man/tuto ... evice.html
hannibalstgt
Post by hannibalstgt » Tue Jan 09, 2018 12:19 pm
Vielen Dank,
es hat funktioniert
Wolfgang
Many thanks,
it worked
Wolfgang
