2.1.3 for XP?
mikeborok
Operating System: Windows XP
2.1.3 for XP?
Post by mikeborok » Thu Jan 04, 2018 1:20 am
Per the Wiki, version 2.1.3 is compatible with my XP SSE2 CPU; 2.21 is not. But I don't see anywhere that 2.1.3 can be downloaded. Looking at the Legacy Downloads page, it says that 2.0.6 is ok for XP without SSE2 or service pack 3 - is this also the correct version for my XP/SSE2/service pack 3 system?
Also - I currently have version 1.2.6 installed... will the new version overwrite this? My concern is that if there is a problem with a new download, I might not be able to get back to 1.2.6.
Thanks.
Mike
Re: 2.1.3 for XP?
Post by steve » Thu Jan 04, 2018 9:20 am
Audacity 1.2.6: https://code.google.com/archive/p/audac ... ads?page=6
The links on the website need to be updated for the other versions, but in the mean time:
2.1.3 is available here: http://www.oldfoss.com/Audacity.html
2.0.6 is available here: https://sourceforge.net/projects/audaci ... ity/2.0.6/
mikeborok
Re: 2.1.3 for XP?
Post by mikeborok » Thu Jan 04, 2018 3:44 pm
Thanks - and what about this?
Re: 2.1.3 for XP?
Post by steve » Thu Jan 04, 2018 9:20 pm
Yes, installing 2.1.3 will overwrite 1.2.6. That's why I gave you a link for 1.2.6 as well.
Andrewacd
Re: 2.1.3 for XP?
Post by Andrewacd » Fri Apr 19, 2019 5:36 am
Audacity 1.2.6: https://code.google.com/archive/p/audacity/downloads?page=6
2.0.6 is available here: https://sourceforge.net/projects/audacity/files/audacity/2.0.6/
2.1.3 isn't available there or anywhere I look.
Re: 2.1.3 for XP?
Post by steve » Fri Apr 19, 2019 8:32 am
FossHub have reorganised their site since January 2018 (when the previous links were posted).
There are now some old versions of Audacity here: https://www.fosshub.com/Audacity-old.html
