Distorted exported MP3 tracks
julia63
Post by julia63 » Sun May 03, 2009 3:22 pm
I have looked in all the written information and can not find the answer to this problem. After I edit a aup track I export it to MP3. The MP3 file sound is distorted. It may have clipping or may not. Sometimes this happens and sometimes it doesn't. I also am getting distorted aup tracks after I save and reopen. I have tried I/O sliding without results. Is there a feature on audacity I haven't discovered that can restore these tracks to the original sound? I am editing talks not music. :cry: I am using 1.25 Audacity. I couldn't figure out how to export to MP3 in 1.3x version. Thanks for any help!
Re: Distorted exported MP3 tracks
Post by kozikowski » Mon May 04, 2009 5:30 am
<<<After I edit a aup track I export it to MP3.>>>
An AUP file is an Audacity Project Manager. It's job is to keep track of all the editing you did and where all the parts of your show are. It's not a track or a sound file.
Audacity will try to add up all your active tracks when you Export. If that sum comes out to over 100%, then you will get a distorted Export. If you sense the Exported show getting crunchy or harsh, apply the amplify tool to all the tracks equally and reduce the level of everything 3dB. More if the crunchy is severe.
I bet you're asking yourself if there is any way to catch this ahead of time. I'm wondering that myself. You're not the first poster to get burned with this.
Udo
Post by Udo » Fri May 07, 2010 10:13 pm
Hi,
I have been using Audacity 1.3.6 up to now. Since I installed the latest version (1.3.12), I have sever quality problems exporting to mp3 with 128kbs.
It seems to be a problem related to Lame. 1.3.7 upwards requirers Lame 3.98.
I have done some testing. Please listen to the mp3s attached, it speaks for itself.
Regards
Udo
P.S.: can I only upload 3 files?
Test 1.3.6 & Lame 3.39.mp3
(164.93 KiB) Downloaded 359 times
Test 1.3.2 & Lame 3.39.mp3
(165.31 KiB) Downloaded 315 times
Test 1.3.2 & Lame 3.98 .mp3
(165.31 KiB) Downloaded 288 times
Udo
Post by Udo » Fri May 07, 2010 10:15 pm
Here are the other 2 files
Regards
Udo
Test 1.3.12 & Lame 3.98.mp3
(166.12 KiB) Downloaded 326 times
Test 1.3.7 & Lame 3.98.mp3
(166.12 KiB) Downloaded 274 times
Post by steve » Sat May 08, 2010 9:56 am
The recommended version of Lame for Audacity 1.3.12 is version 3.98.2 which is available from the link on this page: http://audacityteam.org/help/faq?s=inst ... m=lame-mp3
billw58
Post by billw58 » Sat May 08, 2010 6:14 pm
Udo:
I downloaded the fifth file (1.3.12 with Lame 3.98) and the levels are extremely low. I was able to amplify it by 23.8 dB. I don't hear distortion so much as intermodulation of the piano and the noise, particularly a spike at around 100 Hz.
Try doing Effect > Amplify before you export and see if that helps. Better still is to get the levels right when recording.
What is your setup? What machine, what OS, how are you getting sound into the machine, and what external equipment are you using?
-- Bill
Udo
Post by Udo » Sun May 09, 2010 2:46 am
Hi Bill (and stevethefiddle),
I am aware that the original recording is at low a level (and one of the microphones has a slight hissing problem). My point is that the lame 3.98.2 (which I was referring to when indicating 3.98) is remarkably distorted when compressing to mp3 128kbs (constant) compared to the 3.39 version. Just download the file "Test 1.3.6 Lame 3.3.9" and compare for yourself.
I have tested it on Windows 7, Vista and Windows XP; all the same result. Hence, I reverted back to 1.3.6 in order to be able to use the old Lame version. I was just wondering why nobody seems to bother and just increase the kbs. 128 works fine for me. I would like to see that the development team considers this so that we can all enjoy better quality at 128kbs in newer versions of Audacity.
Regards
Udo
Udo
Post by Udo » Sun May 09, 2010 2:49 am
By the way, I am recording using an external Lexicon Lamda sound device. All original recordings are of good quaity; only when I export to mp3 the diminissed quality becomes an issue.
Regards
Udo
Post by steve » Sun May 09, 2010 1:30 pm
Could you upload the same recording as a WAV file so that we can run a comparison.
Udo
Post by Udo » Sun May 09, 2010 9:20 pm
Hi Steve,
Here it is (I had to cut it down to below 1MB).
Regards
Udo
Test 1.3.6.WAV
(833.32 KiB) Downloaded 85 times
