Dear All,
We have a voice track recorded while screening a movie. Though noise reduction supports a lot in removing noise, I find it is very difficult to remove "vibrating" like distortions buried in voice. I have attached a sample herewith.
https://dl.getdropbox.com/s/umbka4zmqqf3c5v/cut.wav
Appreciate your support.
Thanks!
Remove distortion buried within voice
Re: Remove distortion buried within voice
What was it like before you worked on it and do you have anything longer than four seconds? We can't take effects and filters out of a performance. It sounds like you may have created some of the damage yourself. Noise Reduction is not a cure-all.
