recording live broadcast/stream
gord29
Post by gord29 » Sun May 03, 2009 7:27 am
How do you record a live broadcast program you are listening to on the computer?
waxcylinder
Re: recording live broadcast/stream
Post by waxcylinder » Sun May 03, 2009 1:51 pm
See my PM resonse to your PM - and please don't double post !
gord29
Post by gord29 » Fri May 22, 2009 3:01 pm
gord29 wrote:How do you record a live broadcast program you are listening to on the computer? (or any other sound coming over your speakers)
I did this by right clicking over the speaker icon in the task bar and opening recording devices. Then right clicking over one of the devices listed. Then checking 'show disabled devices' and 'show disconnected devices'. Stereo Mix appeared. It was disabled so I checked 'enable'. I opened Audacity. I started a track in itunes. I started 'record' in Audacity. It worked. Make sure your 'mic' volume is turned up at the top of the Audacity screen. Right click over the speaker icon in the task bar again. Select 'open volume mixer'. Make sure something isn't muted. I have Vista Home version.
