Constant crashes
Please state:
Re: Constant crashes
Post by steve » Wed Oct 10, 2018 1:32 pm
pasuspender shouldn't be necessary. All that does is to suspend (temporarily disable) PulseAudio, but if nothing is using PulseAudio it will suspend itself anyway without pasuspender.
Note that if Pulse Audio Volume Control is open, the PulseAudio is active and will grab exclusive control of your sound card.
Another alternative to using the "hw:" device if crashing is happening on playback, is to use dmix for playback.
mxdxz
Operating System: OS X 10.6 Snow Leopard or earlier
Post by mxdxz » Wed Oct 10, 2018 2:03 pm
Well, I tried rebooting the computer, and made sure no other desktop app (including pavucontrol) was running. Nothing helped except pasuspender.
Post by steve » Wed Oct 10, 2018 2:09 pm
Including your web browser? That's caught me out a couple of times when there was a page loaded but not visible that contained media, and a browser plug-in was using Pulse.
Note also that when Audacity first opens, it scans the sound system, including Pulse, so Pulse will be active for a few seconds after launching Audacity.
(Audacity 2.3.0 works around this by retrying a few times, so as to give Pulse chance to time-out and suspend itself. For earlier version, I'd suggest waiting 30 seconds after launching Audacity before attempting to record with "hw:").
mxdxz
Post by mxdxz » Wed Oct 10, 2018 6:31 pm
Yes, including the browser. Audacity was literally the first and only app I launched after a fresh boot. I also tried restarting it.
