Batch Converting
WB9SBD
Batch Converting
Post by WB9SBD » Thu Dec 07, 2017 11:12 pm
learned how to do a batch converting using chains,
BUT when choosing a .wav as the file format to save as, is there any way to choose the quality level ie: sample rates etc.?
Re: Batch Converting
Post by steve » Thu Dec 07, 2017 11:45 pm
If you only want to batch convert formats, there are better programs to use. However, to answer your question directly, when exporting with a Chain, Audacity will use the same export settings as were used the last time that it exported in that format. For example, if you want to export as 256 kbps CBR MP3 in a Chain, then before running the Chain, create a small 'dummy' project and export as 256 kbps CBR MP3, then restart Audacity and run the Chain.
