PROBLEMS GETTING STARTED!
Help for Audacity on macOS.
Woodpecker
Post by Woodpecker » Wed Dec 06, 2017 11:16 pm
I have done quite a number of successful digitisations using Audacity in the past, but not recently. Now nothing works, just squealing acoustic feedback and when recording level is reduced no signal at all.
Details: Mac OS X 10.13.1 High Sierra
Audacity 2.1.0
I started using a brand new small Cassette player as the source, joined to iMac by the players own cable terminating in USB plug. When that didn't work (with symptoms as above) I reverted to my old system of connecting from a high end DENON cassette player, reaching the iMac's USB socket through a Behringer UCA22 link-up (converts two separate radio plugs to one USB cable.). This was the arrangement I have used many times when digitising LP records. In both cases the cable comes from the pre-amp sockets on the back of the amplifier in the Hi Fi setup I have.
Sadly the result was exactly the same: acoustic feedback, with no signal when recording level was reduced.
What I am I now doing wrong that I wasn't a year ago?
billw58
Re: PROBLEMS GETTING STARTED!
Post by billw58 » Wed Dec 06, 2017 11:50 pm
At the Device Toolbar, set the input to "USB Audio Codec".
Also, you should upgrade to the latest Audacity, which as of tomorrow should be version 2.2.1, available here
-- Bill
