How do you open a project without a .aup file?
Xirix
Operating System: Windows 7
Post by Xirix » Fri Dec 01, 2017 11:08 pm
Friend of mine just gave me some audio he wants editing from a while back, all he has is the project folder, not the actual project file, how can I import this into audacity? All the options seem to want files, not folders.
Trebor
Re: How do you open a project without a .aup file?
Post by Trebor » Sat Dec 02, 2017 1:17 am
Xirix wrote:... all he has is the project folder, not the actual project file, how can I import this into audacity?
I hope you like jigsaw puzzles, see ... http://manual.audacityteam.org/man/reco ... l_recovery
Post by kozikowski » Sat Dec 02, 2017 2:45 am
If it's a mono, fresh recording with no changes or edits, you might be able to use that process to piece it back together. If it's stereo, the show may assemble with left and right sound reversing at random times.
If the show has any edits or other changes, that's the end. There is no show.
