cut and paste
Help for Audacity on macOS.
blad
cut and paste
Post by blad » Fri Dec 01, 2017 8:27 pm
Audacity 2.2 will not allow for cut and paste. Specifically; pulling text and pasting to track labeling. App goes to failure. Any help Please.
Re: cut and paste
Post by steve » Fri Dec 01, 2017 9:20 pm
blad wrote:Audacity 2.2
Is that 2.1.2 or 2.2.0, or 2.2.1 RC1 or 2.2.1 RC2 or some other version? (look in "Audacity > About Audacity")
blad wrote:Specifically; pulling text and pasting to track labeling. App goes to failure
Please give exact steps to reproduce the problem (cut and paste works for me, but I may not be doing what you are doing)
blad
Re: cut and paste
Post by blad » Sat Dec 02, 2017 5:33 am
Thanks, My steps are simple. I select my track label>copy text from the web>paste text to pre-selected track label. Audacity 2.2.0 goes to failure. It allows me to recover but, for some reason it is not allowing the paste action to occur. I have a very old mac pro 2006 and it's relevance is fleeting. The OS is maxed for this unit at 10.7.5. This does meet Audacity 2.2.0 requirements. Thanks for any help.
Re: cut and paste
Post by steve » Sat Dec 02, 2017 3:08 pm
blad wrote:Audacity 2.2.0 goes to failure.
Do you mean that Audacity 'crashes' (the application suddenly disappears and is no longer running)?
I'm not able to reproduce that.
Does it always happen?
Does it happen if you paste just a single word?
How exactly are you pasting the text in the label (step by step, how do I exactly repeat what you are doing)?
blad
Re: cut and paste
Post by blad » Sat Dec 02, 2017 5:24 pm
No, It does not crash and yes it happens every time. Audacity 2.2.0 displays a log and asks if I would like to recover my present work. It just seems to not allow for the paste to occur. Regarding my process for cut and paste is standard. I simply copy text from Discog.com (my source for most info regarding record albums) and paste to preassigned track label in Audacity 2.2.0. A single word of text is occasionally used but, mostly a phrase. It makes no difference.
For your reference I have a problem with an intermittent record. Please refer to my post regarding this "intermittent record". I'm concerned that this might be related. Thanks Steve.
billw58
Re: cut and paste
Post by billw58 » Sat Dec 02, 2017 6:45 pm
blad wrote: Audacity 2.2.0 displays a log and asks if I would like to recover my present work.
That's a crash.
In the Finder, go to the Utilities folder and start the Console app. Under "User Diagnostic Reports" there should be reports about the Audacity crashes. Copy one of those reports and paste it into a message here.
Like Steve, I cannot reproduce this. I'm using Audacity 2.2.0 on OS X 10.11.4 on and Intel iMac.
-- Bill
blad
Re: cut and paste
Post by blad » Wed Dec 06, 2017 12:49 am
That's a crash.
-- Bill
Thanks Bill, This is what I found
Code: Select all
Date/Time:       2017-12-04 09:46:30.613889 -0600
OS Version:      Mac OS X 10.13.1 (Build 17B48)
Architecture:    x86_64
Report Version:  19
Command:         Audacity
Path:            /Applications/Audacity.app/Contents/MacOS/Audacity
Version:         ??? (???)
Parent:          sh [2187]
Responsible:     sh [2187]
PID:             2189
Event:           wakeups
Wakeups:         45497 wakeups over the last 235 seconds (193 wakeups per second average), exceeding limit of 150 wakeups per second over 300 seconds
Action taken:    none
Duration:        235.32s
Steps:           87
Hardware model:  MacPro6,1
Active cpus:     12
Fan speed:       790 rpm
Powerstats for:  Audacity [2189]
UUID:            5263752E-6331-3BA1-AB88-778F6B82F63C
Start time:      2017-12-04 09:46:31 -0600
End time:        2017-12-04 09:50:22 -0600
Microstackshots: 87 samples (100%)
Primary state:   39 samples Non-Frontmost App, User mode, Effective Thread QoS User Interactive, Requested Thread QoS User Interactive, Override Thread QoS Unspecified
User Activity:   0 samples Idle, 87 samples Active
Power Source:    0 samples on Battery, 87 samples on AC
  77 main + 30 (Audacity) [0xd52e]
    77 wxEntry(int&, char**) + 50 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c3dc42]
      77 wxEntry(int&, wchar_t**) + 83 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c3db03]
        77 wxApp::OnRun() + 30 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16105ae]
          77 wxAppConsoleBase::MainLoop() + 117 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd04a5]
            77 wxEventLoopBase::Run() + 89 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c013f9]
              77 wxCFEventLoop::DoRun() + 47 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cb737f]
                77 wxGUIEventLoop::OSXDoRun() + 107 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x167beab]
                  76 -[NSApplication run] + 763 (AppKit) [0x9135a2e1]
                    76 -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 134 (AppKit) [0x91ad6141]
                      76 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2859 (AppKit) [0x91ad6c74]
                        76 _DPSNextEvent + 2101 (AppKit) [0x9136538d]
                          76 _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox) [0x92f0d73b]
                            76 ReceiveNextEventCommon + 777 (HIToolbox) [0x92f0da62]
                              76 RunCurrentEventLoopInMode + 321 (HIToolbox) [0x92f0dd3b]
                                76 CFRunLoopRunInMode + 122 (CoreFoundation) [0x9390c9aa]
                                  76 CFRunLoopRunSpecific + 641 (CoreFoundation) [0x9390cc41]
                                    51 __CFRunLoopRun + 1981 (CoreFoundation) [0x9390d72d]
                                      43 __CFRunLoopDoObservers + 498 (CoreFoundation) [0x9392a132]
                                        39 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 22 (CoreFoundation) [0x9392a216]
                                          25 wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*) + 87 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cb6be7]
                                            25 wxEventLoopBase::ProcessIdle() + 35 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c014e3]
                                              16 wxApp::ProcessIdle() + 31 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x161055f]
                                                8  wxAppBase::ProcessIdle() + 26 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16a60fa]
                                                  8  wxAppConsoleBase::ProcessIdle() + 85 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd06c5]
                                                    6  wxEvtHandler::ProcessEvent(wxEvent&) + 102 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda3d6]
                                                      4  wxEvtHandler::ProcessEventLocally(wxEvent&) + 98 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda4e2]
                                                        3  wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 304 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cd98f0]
                                                          2  wxAppConsoleBase::CallEventHandler(wxEvtHandler*, wxEventFunctor&, wxEvent&) const + 71 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd0cf7]
                                                            2  wxAppConsoleBase::HandleEvent(wxEvtHandler*, void (wxEvtHandler::*)(wxEvent&), wxEvent&) const + 39 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd0ca7]
                                                              1  wxApp::OnIdle(wxIdleEvent&) + 19 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x160fc03]
        1  <Frontmost App>
                                                              1  wxApp::OnIdle(wxIdleEvent&) + 4 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x160fbf4]
        1  <Frontmost App>
                                                          1  wxAppConsoleBase::CallEventHandler(wxEvtHandler*, wxEventFunctor&, wxEvent&) const + 20 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd0cc4]
                                                            1  <Frontmost App>
                                                        1  wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 156 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cd985c]
                                                      2  wxEvtHandler::ProcessEventLocally(wxEvent&) + 70 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda4c6]
                                                        1  wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 231 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda757]
                                                          1  <Frontmost App>
                                                        1  wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 64 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda6b0]
                                                          1  <Frontmost App>
                                                    2  ToolManager::FilterEvent(wxEvent&) + 256 (Audacity) [0x3e3aa0]
                                                      2  <Frontmost App>
                                                7  wxAppBase::ProcessIdle() + 151 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16a6177]
                                                  4  wxWindowBase::SendIdleEvents(wxIdleEvent&) + 114 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7b82]
                                                    3  wxWindowBase::SendIdleEvents(wxIdleEvent&) + 32 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7b30]
                                                      2  wxWindowBase::OnInternalIdle() + 18 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7bc2]
                                                        2  wxUpdateUIEvent::CanUpdate(wxWindowBase*) + 60 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x15be6ac]
                                                          2  wxWindowBase::IsShownOnScreen() const + 1 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a4e21]
                                                            2  <Frontmost App>
                                                      1  wxWindowBase::OnInternalIdle() + 41 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7bd9]
                                                        1  wxWindowBase::UpdateWindowUI(long) + 128 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7920]
                                                          1  wxEvtHandler::ProcessEvent(wxEvent&) + 230 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda456]
                                                            1  wxWindowBase::TryAfter(wxEvent&) + 28 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a880c]
                                                              1  <Frontmost App>
                                                    1  wxWindowBase::SendIdleEvents(wxIdleEvent&) + 114 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7b82]
                                                      1  wxWindowBase::SendIdleEvents(wxIdleEvent&) + 32 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7b30]
                                                        1  wxHtmlWindow::OnInternalIdle() + 26 (libwx_osx_cocoau_release_html-3.0.0.2.0.dylib) [0x13a0f2a]
                                                            1  wxWindowBase::UpdateWindowUI(long) + 371 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7a13]
                                                              1  <Frontmost App>
                                                  1  wxWindowBase::SendIdleEvents(wxIdleEvent&) + 70 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7b56]
                                                    1  wxEvtHandler::SafelyProcessEvent(wxEvent&) + 34 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda7a2]
                                                      1  wxEvtHandler::ProcessEvent(wxEvent&) + 102 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda3d6]
                                                        1  wxEvtHandler::ProcessEventLocally(wxEvent&) + 98 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cda4e2]
                                                          1  wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 357 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cd9925]
                                                            1  <Frontmost App>
                                                  1  wxFrameBase::OnInternalIdle() + 1 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16fe6e1]
                                                    1  <Frontmost App>
                                                      1  wxFrameBase::UpdateWindowUI(long) + 26 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16fe56a]
                                                        1  wxWindowBase::UpdateWindowUI(long) + 152 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x17a7938]
                                                          1  <Frontmost App>
                                                1  wxAppBase::ProcessIdle() + 115 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16a6153]
                                                  1  <Frontmost App>
                                              6  wxApp::ProcessIdle() + 23 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x1610557]
                                                5  wxMacAutoreleasePool::wxMacAutoreleasePool() + 59 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x162faab]
                                                  5  -[NSAutoreleasePool init] + 13 (Foundation) [0x952c9eea]
                                                    3  call_load_methods + 762 (libobjc.A.dylib) [0xa6a5042f]
                                                      3  <Frontmost App>
                                                    2  _CFAutoreleasePoolPush + 10 (CoreFoundation) [0x938cd14a]
                                                      2  objc_autoreleasePoolPush + 110 (libobjc.A.dylib) [0xa6a5049d]
                                                        2  <Frontmost App>
                                                1  wxMacAutoreleasePool::wxMacAutoreleasePool() + 23 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x162fa87]
                                              2  wxApp::ProcessIdle() + 41 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x1610569]
                                                2  -[NSAutoreleasePool release] + 1 (Foundation) [0x952e5c4a]
                                              1  wxMacAutoreleasePool::wxMacAutoreleasePool() + 1 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x162fa71]
                                                1  <Frontmost App>
                                          5  _NSGestureRecognizerUpdate + 1849 (AppKit) [0x91dcd9d6]
                                            2  _NSGestureRecognizerRemoveObjectsFromArrayAndApplyBlocks + 204 (AppKit) [0x91dd2f4d]
                                              2  CFArrayRemoveAllValues + 147 (CoreFoundation) [0x93929633]
                                                2  -[__NSArrayM removeAllObjects] + 122 (CoreFoundation) [0x9392dc3a]
                                            2  _NSGestureRecognizerRemoveObjectsFromArrayAndApplyBlocks + 118 (AppKit) [0x91dd2ef7]
                                              1  CFArrayGetValues + 34 (CoreFoundation) [0x938c7102]
                                              1  CFArrayGetValues + 288 (CoreFoundation) [0x938c7200]
                                            1  CFArrayGetValues + 1 (CoreFoundation) [0x938c70e1]
                                          2  _NSGestureRecognizerUpdate + 96 (AppKit) [0x91dcd2fd]
                                          2  _os_unfair_lock_corruption_abort + 39 (libsystem_platform.dylib) [0xa7784955]
                                          2  _NSGestureRecognizerUpdate + 61 (AppKit) [0x91dcd2da]
                                            2  CFArrayGetCount + 160 (CoreFoundation) [0x938b6900]
                                          1  _NSGestureRecognizerUpdate + 2355 (AppKit) [0x91dcdbd0]
                                            1  <Frontmost App>
                                          1  _NSGestureRecognizerUpdate + 1870 (AppKit) [0x91dcd9eb]
                                          1  _Block_object_assign + 346 (libsystem_blocks.dylib) [0xa7551e19]
                                        3  _NSGestureRecognizerUpdateObserver + 1 (AppKit) [0x91dcd293]
                                        1  wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*) + 1 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cb6b91]
                                      2  __CFRunLoopDoObservers + 259 (CoreFoundation) [0x9392a043]
                                        2  CFRetain + 84 (CoreFoundation) [0x938961b4]
                                          2  _CFRetain + 355 (CoreFoundation) [0x93896343]
                                      2  __CFRunLoopDoObservers + 425 (CoreFoundation) [0x9392a0e9]
                                      1  __CFRunLoopDoObservers + 580 (CoreFoundation) [0x9392a184]
                                        1  CFRelease + 24 (CoreFoundation) [0x9389c1b8]
                                      1  __CFRunLoopDoObservers + 262 (CoreFoundation) [0x9392a046]
                                      1  __CFRunLoopDoObservers + 112 (CoreFoundation) [0x93929fb0]
                                        1  objc_msgSend + 64 (libobjc.A.dylib) [0xa6a4f190]
                                      1  __CFRunLoopDoObservers + 436 (CoreFoundation) [0x9392a0f4]
                                        1  _pthread_mutex_unlock_slow + 415 (libsystem_pthread.dylib) [0xa778872d]
                                    11 __CFRunLoopRun + 3211 (CoreFoundation) [0x9390dbfb]
                                      8  __CFRunLoopDoTimers + 395 (CoreFoundation) [0x93915fbb]
                                        4  __CFRunLoopDoTimer + 2176 (CoreFoundation) [0x93916900]
                                          3  __CFRepositionTimerInMode + 93 (CoreFoundation) [0x938e3d8d]
                                            3  CFArrayRemoveValueAtIndex + 94 (CoreFoundation) [0x9391723e]
                                              2  _CFArrayReplaceValues + 380 (CoreFoundation) [0x938bb21c]
                                                2  __CFTypeCollectionRelease + 1 (CoreFoundation) [0x938cba21]
                                                  2  <Frontmost App>
                                              1  _CFArrayReplaceValues + 115 (CoreFoundation) [0x938bb113]
                                                1  <Frontmost App>
                                          1  __CFRepositionTimerInMode + 128 (CoreFoundation) [0x938e3db0]
                                            1  mk_timer_arm + 10 (libsystem_kernel.dylib) [0xa7653e96]
                                              1  <Frontmost App, Kernel mode>
                                        3  __CFRunLoopDoTimer + 1856 (CoreFoundation) [0x939167c0]
                                          3  __CFRunLoopFindMode + 176 (CoreFoundation) [0x938de8b0]
                                            3  CFSetGetValue + 96 (CoreFoundation) [0x938dee00]
                                              2  CFBasicHashFindBucket + 1028 (CoreFoundation) [0x9389a834]
                                                2  CFEqual + 48 (CoreFoundation) [0x938a9be0]
                                                  2  <Frontmost App>
                                              1  CFBasicHashFindBucket + 164 (CoreFoundation) [0x9389a4d4]
                                                1  CFHash + 100 (CoreFoundation) [0x93897e14]
                                                  1  <Frontmost App>
                                        1  __CFRunLoopDoTimer + 1498 (CoreFoundation) [0x9391665a]
                                          1  <Frontmost App>
                                      3  __CFRunLoopDoTimers + 455 (CoreFoundation) [0x93915ff7]
                                        3  objc_release + 29 (libobjc.A.dylib) [0xa6a4fd03]
                                          3  -[NSObject release] + 19 (libobjc.A.dylib) [0xa6a512d0]
                                            3  objc_object::sidetable_release(bool) + 269 (libobjc.A.dylib) [0xa6a539f9]
                                              1  _cache_collect + 452 (libobjc.A.dylib) [0xa6a58582]
                                                1  <Frontmost App>
                                              1  -[__NSArrayM dealloc] + 49 (CoreFoundation) [0x938ba201]
                                                1  cow_cleanup + 139 (CoreFoundation) [0x939b0b7b]
                                                  1  free + 386 (libsystem_malloc.dylib) [0xa76b6e6e]
                                                    1  default_zone_free_definite_size + 57 (libsystem_malloc.dylib) [0xa76c5095]
                                                      1  szone_free_definite_size + 138 (libsystem_malloc.dylib) [0xa76b7239]
                                                        1  free_tiny + 4 (libsystem_malloc.dylib) [0xa76cb123]
                                              1  -[__NSArrayM dealloc] + 82 (CoreFoundation) [0x938ba222]
                                                1  _object_dispose(objc_object*) + 20 (libobjc.A.dylib) [0xa6a58596]
                                                  1  objc_destructInstance + 59 (libobjc.A.dylib) [0xa6a4fd5e]
                                                    1  objc_object::sidetable_clearDeallocating() + 118 (libobjc.A.dylib) [0xa6a4ffac]
                                                      1  bool objc::DenseMapBase<objc::DenseMap<DisguisedPtr<objc_object>, unsigned long, true, objc::DenseMapInfo<DisguisedPtr<objc_object> > >, DisguisedPtr<objc_object>, unsigned long, objc::DenseMapInfo<DisguisedPtr<objc_object> >, true>::LookupBucketFor<DisguisedPtr<objc_object> >(DisguisedPtr<objc_object> const&, std::__1::pair<DisguisedPtr<objc_object>, unsigned long> const*&) const + 143 (libobjc.A.dylib) [0xa6a64d39]
                                    4  __CFRunLoopRun + 1920 (CoreFoundation) [0x9390d6f0]
                                      3  __CFRunLoopServiceMachPort + 296 (CoreFoundation) [0x9390e858]
                                        3  mach_msg_trap + 10 (libsystem_kernel.dylib) [0xa7653d22]
                                          2  <Frontmost App, Kernel mode>
                                          1  <Kernel mode>
                                      1  __CFRunLoopServiceMachPort + 429 (CoreFoundation) [0x9390e8dd]
                                    2  __CFRunLoopRun + 1748 (CoreFoundation) [0x9390d644]
                                      2  __CFRunLoopDoSources0 + 138 (CoreFoundation) [0x9390e4ea]
                                        2  CFSetApplyFunction + 145 (CoreFoundation) [0x938df5b1]
                                          1  CFBasicHashApply + 110 (CoreFoundation) [0x938ccafe]
                                            1  __CFSetApplyFunction_block_invoke + 21 (CoreFoundation) [0x938df615]
                                              1  __CFRunLoopCollectSources0 + 22 (CoreFoundation) [0x9390e656]
                                          1  CFBasicHashApply + 28 (CoreFoundation) [0x938ccaac]
                                    2  __CFRunLoopRun + 1661 (CoreFoundation) [0x9390d5ed]
                                      1  __CFRunLoopDoObservers + 498 (CoreFoundation) [0x9392a132]
                                        1  __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 22 (CoreFoundation) [0x9392a216]
                                          1  wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*) + 68 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cb6bd4]
                                            1  wxAppConsoleBase::ProcessPendingEvents() + 238 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd0b6e]
                                      1  __CFRunLoopDoObservers + 259 (CoreFoundation) [0x9392a043]
                                        1  CFRetain + 4 (CoreFoundation) [0x93896164]
                                    2  __CFRunLoopRun + 2054 (CoreFoundation) [0x9390d776]
                                      2  _kernelrpc_mach_port_insert_member_trap + 10 (libsystem_kernel.dylib) [0xa7653cc2]
                                        2  <Kernel mode>
                                    1  __CFRunLoopRun + 2262 (CoreFoundation) [0x9390d846]
                                      1  __CFRunLoopServiceMachPort + 296 (CoreFoundation) [0x9390e858]
                                        1  mach_msg_trap + 10 (libsystem_kernel.dylib) [0xa7653d22]
                                          1  <Kernel mode>
                                    1  __CFRunLoopRun + 1639 (CoreFoundation) [0x9390d5d7]
                                    1  __CFRunLoopRun + 2940 (CoreFoundation) [0x9390daec]
                                      1  mach_absolute_time + 20 (libsystem_kernel.dylib) [0xa76532e9]
                                    1  __CFRunLoopRun + 2035 (CoreFoundation) [0x9390d763]
                  1  -[NSApplication run] + 838 (AppKit) [0x9135a32c]
                    1  -[wxNSApplication sendEvent:] + 148 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x15c8174]
                      1  -[NSApplication(NSEvent) sendEvent:] + 2590 (AppKit) [0x91ad50ea]
                        1  -[wxNSWindow sendEvent:] + 146 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x1687412]
                          1  -[NSWindow(NSEventRouting) sendEvent:] + 475 (AppKit) [0x91c77ca4]
                            1  -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 6621 (AppKit) [0x91c79a33]
                              1  -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5327 (AppKit) [0x91c7ba98]
                                1  wxOSX_mouseEvent(NSView*, objc_selector*, NSEvent*) + 52 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x1699fb4]
                                  1  wxWidgetCocoaImpl::mouseEvent(NSEvent*, NSView*, void*) + 278 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x169a9b6]
                                    1  -[NSControl mouseDown:] + 961 (AppKit) [0x91586ab0]
                                      1  -[NSPopUpButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 681 (AppKit) [0x91659c14]
                                        1  -[NSCarbonMenuImpl popUpMenu:atLocation:width:forView:withSelectedItem:withFont:withFlags:withOptions:] + 508 (AppKit) [0x915ef26b]
                                          1  _NSSLMPopUpCarbonMenu3 + 5611 (AppKit) [0x915f08fa]
                                            1  _HandlePopUpMenuSelectionWithDictionary + 312 (HIToolbox) [0x92f4ccd8]
                                              1  _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned long, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 437 (HIToolbox) [0x930ca3ad]
                                                1  PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned long, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1784 (HIToolbox) [0x930cafcc]
                                                  1  TrackMenuCommon(MenuSelectData&, unsigned char*, SelectionData*, MenuResult*, MenuResult*) + 1681 (HIToolbox) [0x930cf240]
                                                    1  IsUserStillTracking(MenuSelectData*, unsigned char*) + 349 (HIToolbox) [0x92f5e96c]
                                                      1  _NSHLTBMenuEventProc + 186 (AppKit) [0x91ad8160]
                                                        1  -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 134 (AppKit) [0x91ad6141]
                                                          1  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2859 (AppKit) [0x91ad6c74]
                                                            1  _DPSNextEvent + 2101 (AppKit) [0x9136538d]
                                                              1  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox) [0x92f0d73b]
        1  ReceiveNextEventCommon + 777 (HIToolbox) [0x92f0da62]
        1  RunCurrentEventLoopInMode + 321 (HIToolbox) [0x92f0dd3b]
        1  CFRunLoopRunInMode + 122 (CoreFoundation) [0x9390c9aa]
        1  CFRunLoopRunSpecific + 641 (CoreFoundation) [0x9390cc41]
        1  wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*) + 87 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1cb6be7]
        1  wxEventLoopBase::ProcessIdle() + 35 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c014e3]
        1  wxApp::ProcessIdle() + 31 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x161055f]
        1  wxAppBase::ProcessIdle() + 26 (libwx_osx_cocoau_release_core-3.0.0.2.0.dylib) [0x16a60fa]
        1  wxAppConsoleBase::ProcessIdle() + 90 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1bd06ca]
        1  wxLog::FlushActive() + 100 (libwx_baseu_release-3.0.0.2.0.dylib) [0x1c4c4d4]
        1  <Frontmost App>
  8  _pthread_start + 357 (libsystem_pthread.dylib) [0xa778a3b2]
    8  _pthread_body + 347 (libsystem_pthread.dylib) [0xa778a50d]
      6  AudioThread::Entry() + 173 (Audacity) [0x288ed]
        6  __semwait_signal + 10 (libsystem_kernel.dylib) [0xa765d152]
          6  <Kernel mode, Effective Thread QoS Default, Requested Thread QoS Default>
      2  MidiThread::Entry() + 117 (Audacity) [0x29ca5]
        2  __semwait_signal + 10 (libsystem_kernel.dylib) [0xa765d152]
          2  <Kernel mode, Effective Thread QoS Default, Requested Thread QoS Default>
  2  <Kernel mode>
  Binary Images:
              0x1000 -           0xc3effb  Audacity <5263752E-6331-3BA1-AB88-778F6B82F63C> /Applications/Audacity.app/Contents/MacOS/Audacity
           0x135d000 -          0x13e7ffb  libwx_osx_cocoau_release_html-3.0.0.2.0.dylib (3) <9B52ED5C-C1EE-36AC-98C9-53F23C73D242> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_html-3.0.0.2.0.dylib
           0x15b7000 -          0x19b2ff3  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib (3) <16660E51-CAA0-3A39-9059-F7E7223F9991> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_core-3.0.0.2.0.dylib
           0x1bc9000 -          0x1d5aff3  libwx_baseu_release-3.0.0.2.0.dylib (3) <73665C5E-FF90-33BB-B241-6EC4C0262B1D> /Applications/Audacity.app/Contents/Frameworks/libwx_baseu_release-3.0.0.2.0.dylib
          0x91326000 -         0x920e6ff7  com.apple.AppKit 6.9 (1561.10.101) <EF98A262-8FE0-3149-AD52-02C906BF9D30> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x92ee5000 -         0x9327aff7  com.apple.HIToolbox 2.1.1 <2AF1ACB9-424B-38FD-B15C-06AB6D2BAF4F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
          0x9388f000 -         0x93d17ff3  com.apple.CoreFoundation 6.9 (1445.12) <1C6464B2-DFCA-3771-B71C-E7D260D7617C> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x952c6000 -         0x95633ff7  com.apple.Foundation 6.9 (1443.14) <00C5260F-DD85-340F-BBF0-2913EFC92036> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0xa6a4b000 -         0xa6e2b0fb  libobjc.A.dylib (723) <4AF346B8-C1A8-3199-B1BB-ADEDD64D5C1A> /usr/lib/libobjc.A.dylib
          0xa7551000 -         0xa7551fff  libsystem_blocks.dylib (67) <32CE9BB7-E047-3568-981E-4EA94D3DCBB5> /usr/lib/system/libsystem_blocks.dylib
          0xa7640000 -         0xa7663ff3  libsystem_kernel.dylib (4570.20.62) <B304B76C-035B-301C-A31E-0FFF60C5EFB2> /usr/lib/system/libsystem_kernel.dylib
          0xa76b4000 -         0xa76cefff  libsystem_malloc.dylib (140.1.1) <DFE0206A-865E-359D-B2F9-FE9DBB3B5B32> /usr/lib/system/libsystem_malloc.dylib
          0xa7780000 -         0xa7786ffb  libsystem_platform.dylib (161.20.1) <569F5AA2-65B8-35BA-9ECF-8DE1BB8A959A> /usr/lib/system/libsystem_platform.dylib
          0xa7787000 -         0xa7791ff3  libsystem_pthread.dylib (301.20.1) <E3098D4B-9568-3A90-A708-7722BCBC3CBC> /usr/lib/system/libsystem_pthread.dylib
Reason: code tags added to improve readability
blad
Re: cut and paste
Post by blad » Wed Dec 06, 2017 1:04 am
That's a crash.
-- Bill
Code: Select all
Report Version:  19
Command:         Audacity
Version:         ??? (???)
Parent:          sh [2187]
PID:             2189
Event:           wakeups
Action taken:    none
Duration:        235.32s
Steps:           87
Active cpus:     12
Fan speed:       790 rpm
        1  <Frontmost App>
        1  <Frontmost App>
                                                            1  <Frontmost App>
                                                          1  <Frontmost App>
                                                          1  <Frontmost App>
                                                      2  <Frontmost App>
                                                            2  <Frontmost App>
                                                              1  <Frontmost App>
                                                              1  <Frontmost App>
                                                            1  <Frontmost App>
                                                    1  <Frontmost App>
                                                          1  <Frontmost App>
                                                  1  <Frontmost App>
                                                      3  <Frontmost App>
                                                        2  <Frontmost App>
                                                1  <Frontmost App>
                                            1  <Frontmost App>
                                                  2  <Frontmost App>
                                                1  <Frontmost App>
                                                  2  <Frontmost App>
                                                  1  <Frontmost App>
                                          1  <Frontmost App>
                                                1  <Frontmost App>
                                          1  <Kernel mode>
                                        2  <Kernel mode>
                                          1  <Kernel mode>
        1  <Frontmost App>
  2  <Kernel mode>
  Binary Images:
....I should mention that was able to make it work but, very awkward and doesn't in any way seem appropriate or functional. I couldn't even give you a pathway for it because it was very disjointed and I had no idea why it allowed me to paste. After going through the notice it closes audacity and after recovery, audacity allows for a paste. when go to the next label and try to paste it again gives me the notice and I will have to go through the same previous pathway.
billw58
Re: cut and paste
Post by billw58 » Wed Dec 06, 2017 1:26 am
That's not a crash report. Crash reports in Console under "User Diagnostic Rerports" will end with ".crash".
Here's a sample near the beginning of a crash report, showing the kind of information we need:
Code: Select all
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       EXC_I386_GPFLT
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
Validating menu item 'Cut' with action @selector(itemFired:)
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
By the way, this is not a report of an Audacity crash.
Also, we need complete information about the crashed thread, but we do not need the "Binary Images".
Could you give an example of the text you are attempting to paste into the labels?
-- Bill
blad
Re: cut and paste
Post by blad » Wed Dec 06, 2017 1:37 am
blad wrote:
blad wrote:
That's a crash.
-- Bill
blad wrote:
That's a crash.
-- Bill
Code: Select all
Report Version:  19
Command:         Audacity
Version:         ??? (???)
Parent:          sh [2187]
PID:             2189
Event:           wakeups
Action taken:    none
Duration:        235.32s
Steps:           87
Active cpus:     12
Fan speed:       790 rpm
        1  <Frontmost App>
        1  <Frontmost App>
                                                            1  <Frontmost App>
                                                          1  <Frontmost App>
                                                          1  <Frontmost App>
                                                      2  <Frontmost App>
                                                            2  <Frontmost App>
                                                              1  <Frontmost App>
                                                              1  <Frontmost App>
                                                            1  <Frontmost App>
                                                    1  <Frontmost App>
                                                          1  <Frontmost App>
                                                  1  <Frontmost App>
                                                      3  <Frontmost App>
                                                        2  <Frontmost App>
                                                1  <Frontmost App>
                                            1  <Frontmost App>
                                                  2  <Frontmost App>
                                                1  <Frontmost App>
                                                  2  <Frontmost App>
                                                  1  <Frontmost App>
                                          1  <Frontmost App>
                                                1  <Frontmost App>
                                          1  <Kernel mode>
                                        2  <Kernel mode>
                                          1  <Kernel mode>
        1  <Frontmost App>
  2  <Kernel mode>
  Binary Images:
