Default WAV 24-bit extension is .AIFF
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
In the more recent versions of Audacity,
when exporting audio to "Other uncompressed files" -> Header: "WAV (Microsoft)", Encoding: "Signed 24-bit PCM", the file extension gets set to .AIFF when it should be .WAV. (It was .WAV in the previous versions. All encoding types under the header WAV (Microsoft) have the extension .AIFF.) I don't know if this is deliberate or not, but
WAV (Microsoft) signed 16-bit PCM has a .WAV file extension.
WAV (Microsoft) 32-bit float PCM has a .WAV file extension.
It's only right for the 24-bit format to have a .WAV extension as well.
Re: Default WAV 24-bit extension is .AIFF
Please test with Audacity 2.2.0.
For Audacity 2.2.0, the opposite seems to be the case: .WAV is set as the default extension for all other uncompressed files, including AIFF, AU, WAVEX, W64 .. each of which has their own file extension ...steve wrote:Please test with Audacity 2.2.0.
waxcylinder
That looks to be the case when I test on W10 on 2.2.0 (and on 2.2.1 alpha). No account seems to be taken of what the user selects in the Format Options>Header dropdown menu on the Save as type>Other uncompressed files dialog - I would expect to in ideal circumstances.ppw1 wrote:For Audacity 2.2.0, the opposite seems to be the case: .WAV is set as the default extension for all other uncompressed files, including AIFF, AU, WAVEX, W64 .. each of which has their own file extension ...steve wrote:Please test with Audacity 2.2.0.
waxcylinder
waxcylinder
And today it rang an even louder bell as I tested on Windows 10 and macOS High Sierra.waxcylinder wrote:I thought this rang a bell: https://bugzilla.audacityteam.org/show_bug.cgi?id=1355
It appears to be a general bug affecting all platforms whereby:
Accordingly I updated the bug report extending it to all platforms and updated the steps to reproduce and the release note for this bug.The underlying problem would appear to be the when using "Other uncompressed files" as the "Save as type" in the Export dialog when the user goes to the "Format Options" part of the dialog and chooses something other then the default or last-used in the "Header" dropdown - Audacity does not update the file extension in the "File name" data box.
Pressing the OK button will however cause Audacity to export the file in the required format and with the correct extension that the user specified in the "Header" dropdown.
A subsequent visit to The Export Audio dialog will show that Audacity remembers the "Header" type correctly AND it sets the extension in the "File name" correctly. BUT changing the "Header" type to something else shows that then the "File name" extension is once again not visually changed.
I also upgraded it from P3 to P2 (Priority level 2).
Full bug report here: http://bugzilla.audacityteam.org/show_bug.cgi?id=1355
Many thanks for (re)alerting us to this ppw1
Peter
Don't mention it. I'm always happy to helpwaxcylinder wrote: Many thanks for (re)alerting us to this ppw1![]()
Peter
Please also see my other posts for more bug reports / suggestions, heheh
I'd like to note that this bug is still present in version 2.2.2.
waxcylinder
Indeed - and it's still high on my QA list - in fact I sent an email to Team only yesterday highlighting the need to fix tis bug (along with others rated P2).
Unfortunately I can't fix it myself - but I will continue to nag ...
Peter.
Peter.
Well, since I'm here, I may as well write up a list of correct header-extension matches for future reference:
- AIFF (Apple/SGI) - .aiff
AU (Sun/NeXT) - .au
AVR (Audio Visual Research) - .avr
CAF (Apple Core Audio Format) - .caf
HTK (Hidden Markov Model Toolkit) - .htk
IFF (Amiga Interchange File Format/SVX8/SV16) - .iff
MAT4 (Octave 2.0) - .mat
MAT5 (Octave 2.1) - .mat
MPC (Akai MPC 2k) - .mpc
PAF (Ensoniq PARIS) - .paf
PVF (Portable Voice Format) - .pvf
RAW (header-less) - .raw
RF64 (RIFF 64) - .rf64
SD2 (Sound Designer II) - .sd2
SDS (Midi Sample Dump Standard) - .sds
SF (Berkeley/IRCAM/CARL) - .sf
VOC (Creative Labs) - .voc
W64 (SoundFoundry WAVE 64) - .w64
WAV (Microsoft) - .wav
WAV (NIST Sphere) - .wav
WAVEX (Microsoft) - .wav
WVE (Psion Series 3) - .wve
XI (FastTracker 2) - .xi
