Hi,
Just a simple question! macOS High Sierra is released since some time now. Will Audacity 2.1.3 work without any problem with this OS version?
Kind regards
/Thomas
Audacity 2.1.3 & macOS High Sierra
Thomas Rooth
waxcylinder
Re: Audacity 2.1.3 & macOS High Sierra
As an Audacity QA tester I migrated from Sierra to High Sierra very early on - I have had no problems running Audacity 2.2.0 or tyhe alphas fro the upcoming 2.2.1 on my Macbook Pro with High Sierra.
Tested on:
a) my privileged administrator account
b) my standard user account
c) my totally non-privileged guest account
runs fine on all those.
Tested on:
However, there is a bug in the "Chains" feature, so if you rely on using Chains it would probably be best to wait for 2.2.1 which is due to be released in December.waxcylinder wrote:I have had no problems running Audacity 2.2.0 ... on my Macbook Pro with High Sierra.
If you don't use Chains, then I would recommend Audacity 2.2.0 which you can get here: https://www.audacityteam.org/download/mac/
waxcylinder
Oh yes, sorry forgot that.steve wrote:However, there is a bug in the "Chains" feature, so if you rely on using Chains it would probably be best to wait for 2.2.1 which is due to be released in December.waxcylinder wrote:I have had no problems running Audacity 2.2.0 ... on my Macbook Pro with High Sierra.
And there is this one too (also fixed for 2.2.1):
P2 1767 Opening a second project from Mac's Finder produces a second inaccessible instance of Audacity https://bugzilla.audacityteam.org/show_bug.cgi?id=1767
