Bug Report
Please state:
IsaacGibsonYT
Operating System: OS X 10.6 Snow Leopard or earlier
Bug Report
Post by IsaacGibsonYT » Sun Nov 12, 2017 8:38 pm
The file recovery dialog box appears too small to show options for saving, canceling etc. There's no scroll bar to indicate the options. I thought I was stuck until I figured out you could expand the box. Also in the sign up menu for the audacity forums Ubuntu is misspelled to *buntu.
Re: Bug Report
Post by steve » Sun Nov 12, 2017 9:27 pm
IsaacGibsonYT wrote:Also in the sign up menu for the audacity forums Ubuntu is misspelled to *buntu.
That is intended to be a generic term for any of the Ubuntu flavours (https://www.ubuntu.com/about/about-ubuntu/flavours)
IsaacGibsonYT wrote:The file recovery dialog box appears too small to show options for saving, canceling etc.
Which version of Audacity (look in "Help > About Audacity").
What is your display resolution? (screen dpi)
IsaacGibsonYT
Re: Bug Report
Post by IsaacGibsonYT » Sun Nov 12, 2017 10:18 pm
My screen dpi is 170, My screen resolution is 1920x1200, My aspect ratio is 16:10 and I'm using audacity 2.1.3
Re: Bug Report
Post by steve » Sun Nov 12, 2017 10:29 pm
Are you referring to this dialog window:
We are aware that high dpi is not yet fully supported, and that several dialog boxes are displayed incorrectly because of that, but this one (in Audacity 2.1.3 on Xubuntu 16.04) looks OK to me.
IsaacGibsonYT
Re: Bug Report
Post by IsaacGibsonYT » Sun Nov 12, 2017 10:34 pm
Yes I am talking about that dialog window. I'm using Fedora 26 if that helps.
