Hi everybody :
I checked and made a copy of the settings for Audacity version 2.0.5. If I'm using an Mp3 player......or similar device.....what would the input settings be ? And changing these settings back to playback (so I can hear it through my computer ). I'm running Windows 7 Pro 32-bit. Using onboard sound (no separate card) Realtek.
Thanks..............garystan
Recording From Device
Re: Recording From Device
Well... You wouldn't record from an MP3 player, you'd copy the MP3 file (digitally). Same with a CD... You'd use a "CD ripping" application to copy the digital data to a WAV or MP3 file, etc.If I'm using an Mp3 player......or similar device.....
But if you do have something analog, you need a line-level input to connect a line-output or headphone-output. All desktop/tower computers have soundcards with have line-inputs (color-coded blue). Most laptops only have mic-in, but since a line/headphone signal is about 100 times stronger than a mic signal, the mic-input does not work well. If you have a laptop, you'll need a "USB Audio Interface". Don't get a regular "USB soundcard". They are like laptops with only mic-in and headphone-out.
How To Connect Your Equipment.
How To Set Up Audacity.
Are you having a problem with that?And changing these settings back to playback (so I can hear it through my computer ).
