Hi,
tried to figure out what irked me about the new version of Audacity ( 2.2.0 ), this is it:
How can I set the initial view of an opened file's waveform to be "Zoom To Selection" ?
Initial View Changed
waxcylinder
Re: Initial View Changed
You have to wait for the upcoming 2..2.1 - this is a bug that was found in 2.2.0 just after we released it, sorry.
It has already been fixed for 2.2.1. http://bugzilla.audacityteam.org/show_bug.cgi?id=1765
In the meantime just click ion the Zoom to Fit buton in the Edit toolbar - or its shortcut Ctrl + F
You can either:ppw1 wrote:How can I set the initial view of an opened file's waveform to be "Zoom To Selection" ?
import files with the "File menu > Import > Audio"
or
import files by dragging and dropping on an open Audacity window.
