Problem with Commands Sequence
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
jotape1960
Post by jotape1960 » Mon Nov 06, 2017 5:55 pm
I use Audacity into GNU/Linux UbuntuStudio 16.04 LTS.
I upgraded to Audacity 2.2.0, and now I can not to use Commands Sequence with more than one file (as a batch typical process).
I can use Commands Sequence with the audio I have into the screen, only.
Somebody knows something about it??? Is it a bug???
Juan, from Chile.
Re: Problem with Commands Sequence
Post by steve » Mon Nov 06, 2017 6:07 pm
If you're referring to "Chains" (http://manual.audacityteam.org/man/chai ... ation.html), then it's a bug. Unfortunately this bug was not spotted until shortly after 2.2.0 was released. The good news is that there is due to be a new release (2.2.1) in December, and it fixes this bug.
jotape1960
Post by jotape1960 » Mon Nov 06, 2017 6:33 pm
Yes, it's about "Chains".
Well, we have to wait for the final bug fix.
Thanks Steve!!!
