No Export Option Available
Fyve_by_Fyve
Post by Fyve_by_Fyve » Mon Nov 06, 2017 3:11 am
Hello,
I've just gotten a new computer. Downloaded and installed the most recent version of Audacity and the LAME encoder but still have no export option available.
I have used Audacity for years to record vinyl for my weekly online radio program. I cannot use any new albums on the show until I get this sorted.
My turntable connects to a mixer which connects to the soundcard via the Line In jack. I can hear the record and I believe I can record it as well, I just can't export it to .MP3, which does me no good.
There are NO export options available when I click on the File menu.
Any ideas? I need to find a way to record my albums.
I have included a screenshot to show what appears when I pull down the File menu.
audacity 1.jpg (128.84 KiB) Viewed 5179 times
Re: No Export Option Available
Post by kozikowski » Mon Nov 06, 2017 3:21 am
Save Other.
Fyve_by_Fyve
Post by Fyve_by_Fyve » Mon Nov 06, 2017 3:52 am
THANK YOU. Now I see it. Simple solution (yes, i feel stupid).
waxcylinder
Post by waxcylinder » Mon Nov 06, 2017 11:37 pm
Fyve_by_Fyve wrote:THANK YOU. Now I see it. Simple solution (yes, i feel stupid).
No you're not stupid - you are one of the smarter folk who knows you have to export non-native data like audio files. 8-)
We moved the Exports being the "Save Other" as so many folk kept trying to "Save" audio files :geek:
The only thing you can "Save" with Audacity is an Audacity Project (native data).
ppw1
Post by ppw1 » Wed Nov 08, 2017 1:10 pm
Of course, this just buries the export menu one level deeper, which is a big no-no for me.
Any way to reset to the previous version's menu? Apart from going back to the old version.
Any way to customize menus?
waxcylinder
Post by waxcylinder » Wed Nov 08, 2017 2:52 pm
ppw1 wrote:Of course, this just buries the export menu one level deeper, which is a big no-no for me.
Sorry no, old menus means old version - and not getting the other nice 2.2.0 improvements like themes and MIDI playback
ppw1 wrote:Any way to customize menus?
Only if you modify the source code yourself and rebuild.
Though customizable menus is something the developers are thinking about - don't hold your breath though (they are few in number and part time volunteers)
The best workaround is to use the keyboard shortcuts:
a) Ctrl + Shift + E for Export Audio
B) Ctrl + Shift + L for Export Multiple
You can assign your own shortcuts to the Exports to particular formats WAV, MP3 and OGG if required - and you can make single key shortcuts for the existing two.
