Chain conversion crashes Audacity 2.2.0
Merowinger
Hello!
I'm a big fan of the Chain conversion feature of Audacity but it doesn't work with the new version anymore.
I use the feature to normalize and export files in VBR 1 but when I try it with the new version Audacity crashes.
Re: Chain conversion crashes Audacity 2.2.0
The upgrade from Audacity 2.1.3 to 2.2.0 is substantial and there could be some incompatibilities with old settings. Have you tried making a new chain from scratch?
Merowinger
Doesn't work. Same error.
- Attachments
- 001.jpg (62.63 KiB) Viewed 978 times
- 002.jpg (263.51 KiB) Viewed 978 times
Have you tried doing a normal export as MP3 (not from a chain)?
Does the problem occur with one specific project / file?
Merowinger
No, the export works with single files.
Merowinger
And it works with FLACs but not with MP3s.
Update:
It has been verified that there is a problem with some Chains. Developers are working on this now.
Merowinger
Thank you!
A ha! Good to know. I will stop trying to 'fix it' myself :O)
Good luck and godspeed with the solution. THANK YOU.
waxcylinder
And I have QA tested this on Windows 10 and macOS 1.13 High Sierra - now works on both those platforms - just waiting for a Linux test till I can formally close this bug as Resolved.
https://bugzilla.audacityteam.org/show_bug.cgi?id=1770
Peter
Peter
