Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
billw58
Post
by billw58 » Tue Oct 31, 2017 2:37 pm
steve wrote:cbp67 wrote:Another option might be to keep the project file within the folder,
That's more or less how I work:
my_project
- myproject.aup
- myprodect_data
my_project_resources
- my_project_notes.txt
- my_project_lyrics.pdf
- my_project_imported files
- - file1.wav
- - file2.wav
My way of working as well. Also, I create the top-level folder, save and name the project as the very first thing - before I record or import anything. Which means I turn off the warning about saving an empty project.
-- Bill
waxcylinder
Post
by waxcylinder » Tue Oct 31, 2017 4:52 pm
kozikowski wrote:has been much discussed by Team members (including yourself at times)
I didn't discuss it. I just complained about it. I'm not a developer. I'm modeling the Lowly User.
Actually you've discussed this many times here on the Forum - and I carry your views forward to Team/dev discussions on this
And actually your views helped to shape James' views on this ...
And yes "modeling the Lowly User" is useful and appreciated - I try to do the same myself for QA testing
(it's one of the reasons that I don't build the app on Windows or Mac).
Peter
