If you do that, note the headphone connection does not vanish. Switch the UCA-202 monitor ON and the 202 headphone connection becomes active.
Recording volume set?
Re: Recording volume set?
Sure there is. Only, on interfaces that support it. I used to have an old one that even had a "balance" setting. Only saw that once.billw58 wrote:On Mac there is no recording level control for USB audio interfaces.
