Time shifting one channel
jcasqueiro
Post by jcasqueiro » Tue Oct 24, 2017 11:29 pm
Hi,
I want to time shift one of the two channels so that they appear a little unsync.
How can I select just one of the channels (couldn't find any option to do that) and use the timeshift tool on it?
Thanks/Brgds
joao
Re: Time shifting one channel
Post by steve » Wed Oct 25, 2017 10:52 am
You need to split the track into separate left and right channels, then you can work on either of the channels independently. See: http://manual.audacityteam.org/man/spli ... racks.html
jcasqueiro
Post by jcasqueiro » Wed Oct 25, 2017 11:36 am
Thanks
