Refrence to invalid character number at line: 3751
i just closed a project and when i went to open it it gave me this can you plz help me out thanks
- Attachments
- Hang It Up.aup
- (212.43 KiB) Downloaded 65 times
waxcylinder
Re: Refrence to invalid character number at line: 3751
This FAQ from the Audacity Manual should hep you: http://alphamanual.audacityteam.org/man ... _at_line_x
Just be aware that this is the alpha Manual for the as-yet unreleased 2.2.0 version of Audacity - so other pages may/will refer to new stuff. The advice on this page however remains good for 2.1.3 and earlier versions too. I restructured the FAQ for the next release to give clearer advice on errors like this one.
This is actually yet another case of Audacity for Windows not saving supplementary characters properly, a bug that is not even mentioned on the page that you linked to. (Audacity for Windows is saving supplementary characters as pairs of escapes representing surrogates (in the form of
[89ab][0-9a-f][0-9a-f];
[c-f][0-9a-f][0-9a-f]waxcylinder wrote: This FAQ from the Audacity Manual should hep you: http://alphamanual.audacityteam.org/man ... _at_line_x
Anyway, TrillDill, I've attached a version of your project file that doesn't contain the supplementary character.
- Attachments
- Hang It Up.aup
- (212.32 KiB) Downloaded 60 times
We do at least have the bug logged now, and (thanks to you Yarn366) we will hopefully not have this bug much longer.Yarn366 wrote:This is actually yet another case of Audacity for Windows not saving supplementary characters properly, a bug that is not even mentioned on the page that you linked to. (Audacity for Windows is saving supplementary characters as pairs of escapes representing surrogates (in the form of
[c-f][0-9a-f][0-9a-f]when it should be saving them either directly or as five- or six-digit escapes.)
oh wow thank you so much, i was so troubled on that article i got sent your the bestYarn366 wrote:This is actually yet another case of Audacity for Windows not saving supplementary characters properly, a bug that is not even mentioned on the page that you linked to. (Audacity for Windows is saving supplementary characters as pairs of escapes representing surrogates (in the form of
[c-f][0-9a-f][0-9a-f]waxcylinder wrote: This FAQ from the Audacity Manual should hep you: http://alphamanual.audacityteam.org/man ... _at_line_xwhen it should be saving them either directly or as five- or six-digit escapes.)
it happened again with this file do you think you could help me
- Attachments
- pressed.aup
- (93.65 KiB) Downloaded 51 times
What's the exact error message?TrillDill wrote:it happened again with this file do you think you could help me
Which version of Audacity are you using? (I'm guessing that it's an old version).
it didnt give me an exact error message this time, but this time it just silenced all my audio on the track, all the gain and panning settings stayed the same it just deleted all sound, im using 2.1.1steve wrote:What's the exact error message?TrillDill wrote:it happened again with this file do you think you could help me
I can't suggest anything without knowing precisely what the error message said (an exact quote of the error message).
