Not surprised. This machine has two microphones on the left side with the idea they are going to "help me" and I have no idea what the help consists of.slight low end boomy howl I hear in the show.
Also, you're assuming I don't normally sound like that—and then there's the 9dB of noise reduction I applied.
I turned off "Environment Suppression' in the preferences control panel, so that correction/distortion is absent.
In future, I'm going to experiment with desk preconditioning. That recording was done with a towel under the machine. Test with a heavy fabric and again with hard wood surface.
The goal of this test besides confirmation I can't read, is illustrate the equipment you don't need if you have a quiet room.
Also on the docket is further tests with the iPhone. That didn't come out as clean as it was supposed to. Theory has it you should be able to read a book with an iPhone/iPod full stop. Edit in your computer later. Yeti need not apply.
